ThinkDiag OBDII reader
Old May 28, 2021 | 10:42 PM
Tashakes's Avatar
5 Year Member
Tashakes is infamous around these parts
ThinkDiag OBDII reader and code P1000
Hello. I have not been able to clear P1000 to get the car smogged. I did clear misfire codes from 4 and 7 by moving the coils to 3 and 6 to determine if they were bad. They have not thrown codes since the last clear (72 km) I think that clearing the codes also resets P1000 to start over again? Does anyone know if these are the monitors that need to be completed for the code to go away? The reader and software are good, only that there is very little info or support on it.
Last edited by Tashakes; Jun 2, 2021 at 11:43 AM. Reason: Added code to title for future search reference.
Old May 29, 2021 | 09:28 AM
rmrmd1956's Avatar
rmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of light
Yes, those monitors need to run after you clear codes to remove P1000
Old May 30, 2021 | 07:50 AM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Ford Drive Cycles Document
Saved the file from an earlier post this year with the thought it might come in handy, but I don't remember who initially posted it.
Perhaps the information will help with solving your problem?
File Type: pdf
Old May 30, 2021 | 09:08 AM
Tashakes's Avatar
5 Year Member
Thanks for this, most helpful. I am driving today about 100 miles and will be monitoring the scanner. Hopefully I can meet the criteria of each monitor. The most challenging is “steady throttle”. With fuse 22 off and air filter boxes removed, the melody of the V8 is intoxicating!!!
Old May 30, 2021 | 04:39 PM
Tashakes's Avatar
5 Year Member
Update. After about 50 miles only 2 monitors are left to clear.
Old May 31, 2021 | 01:52 PM
rmrmd1956's Avatar
If you want the AM drive cycle among other things, it is attached to this post:
https://www.6speedonline.com/forums/...ml#post4634578
Old Jun 2, 2021 | 11:50 AM
Tashakes's Avatar
5 Year Member
I have tried and tried to get the Catalyst monitor to reset and simply does not. I am following both the V8V and the Ford procedures below. Do you know how hard it is to keep 1130 RPM for 60 seconds?? What were they thinking of!! Anyway, I am going to try again later today. Its not easy to find a road to do all this jumping through hoops either. Any other suggestions are welcome.
ID:	534595   Click image for larger version
ID:	534596   Click image for larger version
Old Jun 2, 2021 | 08:55 PM
Tashakes's Avatar
5 Year Member
Aaarrggg!! Finally cleared the Catalyst monitor and now the Sec Air Monitor is not clearing. Let’s see what happens tomorrow.
Old Jun 6, 2021 | 02:29 PM
Tashakes's Avatar
5 Year Member
Finally P1000 cleared and ready for smog. All it took was around 400 miles. Sheesh. It cleared on the last drive mostly freeway at normal speeds 40 miles each way.
Old Jun 6, 2021 | 05:52 PM
DonL's Avatar
Drive it more?
Glad to hear you're good to go! Sounds like you might need to drive it more often? Enjoy!
Old Jun 6, 2021 | 06:33 PM
J doubleU's Avatar
Great you finally got it. One of the reasons why everyone should have a good battery and driving before a smog check is needed.
Old Jun 6, 2021 | 07:54 PM
Tashakes's Avatar
5 Year Member
Originally Posted by J doubleU;[url=tel:4878855
4878855[/url]]Great you finally got it. One of the reasons why everyone should have a good battery and driving before a smog check is needed.
This and an OBD reader that will tell you if the monitors are clear. Without this there would be a record of “not ready” in the smog history which in my mind is not the best as it shows that there was something (even minor) going on. These readers are a real bargain to get the info and be able to drill down into trouble codes, and should be in every car enthusiast toolbox.
jalmood
Oct 14, 2010 04:52 PM
jalmood
May 1, 2010 06:49 AM
Imolas54
Aug 10, 2008 03:09 PM
Bruce
993
Mar 28, 2007 06:24 PM
skibum
Aug 30, 2006 11:09 PM
