Original 2012 tires - ticking bomb?
Old Oct 2, 2022 | 03:09 PM
Lual's Avatar
Lual is infamous around these parts
I bought few months ago a 5.000 km from new V12V, and have done since then merely 500 more.
Car is like brand new, also tires, but I am afraid I am driving maybe on a ticking bomb and should replace as soon as possible the still original but already 10 years old tires.
I have no issue spending some cash if for safety reasons, but do not like to throw away money if I can still use them for few thousand more Km.
thanks for any view
Old Oct 2, 2022 | 03:24 PM
volvodrummer's Avatar
volvodrummer
Replace ASAP.
Old Oct 2, 2022 | 03:44 PM
msark's Avatar
msark is infamous around these parts
REPLACE ....... You will also find that the new tires, at the same size and pressures are at least 30% more pleasant to drive on .....
Old Oct 2, 2022 | 04:55 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
And if it is like my 2006 DB9 with original tires I had to beat the rims off the wheel hubs due to the rust/corrosion. It was easy to convince myself that the wheels had never been off, that the airfilters had never been replace and that the oil filter was original. And while the filter might have been replaced I don't know how they did it without removing the wheel liner!
Old Oct 2, 2022 | 07:31 PM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
The cheapest insurance you will buy for your car AND you in it is good tires ! Would you ride with some one who you know has bad tires on their car? Don't hesitate another day. If you do..... don't allow passengers. When you get the proper new tires there is a bonus,.....It will ride and handle like a different V12V.
Old Oct 3, 2022 | 03:30 AM
voodoocat's Avatar
voodoocat is infamous around these parts
I bought 2012 Vantage with original tires, plenty of tread. Tires are hard and doesn't have traction, gives out when taking corners. Changed to new and much better. You can't experience the true capabilities of the car with old tires.
Old Oct 3, 2022 | 10:24 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
Around 2K out the door for new tires sounds like a no brainer to me. Get the car aligned while at it. Original air filters? Could be worth replacing since the front wheels will be off the car.
Old Oct 3, 2022 | 05:02 PM
matt75321's Avatar
matt75321 is infamous around these parts
Do some donuts with the old hard tires. And get some new ones.
Old Oct 3, 2022 | 07:42 PM
volvodrummer
Actually, find a parking lot on route to tire shop and do this 1st lol.
Old Oct 3, 2022 | 08:02 PM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Don't hold full steering lock...
Donuts are not a good idea...some "ancient history" from 2012 that resulted in damaging the power steering pump...
https://www.6speedonline.com/forums/...-not-good.html
Old Oct 4, 2022 | 11:38 AM
Marmot's Avatar
5 Year Member
Marmot has a spectacular aura aboutMarmot has a spectacular aura about
I just had some Michelin PS4S put on my Vantage this morning in the later S size and they look great. I was losing air in three of them on my return home post evacuation last week and it was just time. They were 7 years old, on a 2007, so I can't even guess how hard yours are at this point. Just do it. It's not worth the risk.
Old Oct 4, 2022 | 12:35 PM
Lual's Avatar
Thanks for all comments,
pretty clear this is to be done as soon as possible
Old Oct 5, 2022 | 11:40 AM
JaguarSVR's Avatar
JaguarSVR is infamous around these parts
Correct, change them ASAP.
A good friend of mine nearly died in a roll over, that totaled his Elise, caused by old tires.
XWCGT
Apr 9, 2016 05:29 PM
Flying Cat
Jun 21, 2015 12:16 PM
Wedgeduck
Bentley
17
Oct 28, 2012 06:25 AM
Raz5219
Wheels/Tires
Apr 28, 2007 10:29 PM
calh4289
May 28, 2006 10:09 AM
