Porterfield squeaking…..
Old Oct 13, 2025 | 09:14 AM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
I had the OEM brake pads replaced a few months ago with Porterfields. These brakes squeak terribly. At as bad as the OEM. Any thoughts on how to fix the problem? I was thinking they might be glazed since I don’t really really put a lot of pressure on them. Mainly city driving. I have got some speed up and then get them close to locking and it might help a very little. Any ideas?
Old Oct 13, 2025 | 04:36 PM
BWings's Avatar
5 Year Member
BWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond repute
If the porterfields are track pads, squealing comes with the territory, especially if you're just using the car on the streets or GT and not tracking it. If you would go with a ceramic pad, those do exceptionally well on a street car and they shouldn't be noisy. I have ceramics on my street DB11, notorious for squealing and mine doesn't
Besides a good street pad, I use this product and have been for a long time now on every brake job I do. In fact, just did brakes on a Toyota Saturday and used this product. You would have to disassemble everything to just try this stuff, but if it were me, I'd change pads and use this stuff.
Old Oct 13, 2025 | 05:08 PM
Gulf_V8V's Avatar
Gulf_V8V
I got the porterfield S(street) pads, put the antisqueak on the back, then tried to do a proper bedding procedure.
Mine squeaked a bit at slow speeds, but they seemed to have totally bedded in now and are good to go.
If you didn't get the street versions of the pads, you may be SOL and need to swap them out.
Old Oct 13, 2025 | 06:05 PM
kdm's Avatar
kdm
5 Year Member
kdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of light
I installed the street version of the Porterfield pads on our 2007 V8V about 4-5 years ago. Rotors had been cleaned when the new pads were installed and I bedded them in. Had some squealing at low speeds.
Took the pads off and applied some disc brake quiet (can't recall what brand) and bedded them in again.
It helped but still had some squealing for about 200 miles. After that it has all but disappeared.
Old Oct 14, 2025 | 07:49 AM
Argus's Avatar
Thanks for the info. I have the street pads on my car but I have a feeling the shop that installed them did not put any anti squeak on them. I do mainly drive around town at lower speed but I notice if I use the brakes at higher speeds the squeak goes away. I was wondering if Imhave some glazing because of the mainly city driving I do. I will redo the bedding procedure to see if that might help.
Old Oct 14, 2025 | 09:49 AM
MRCW's Avatar
I just replaced rear - poterfield pads and brembo rotors used red antisqueal paste and on street pads no break in required... just normal driving for about 100 miles with nothing aggressive...no noise very little dust
Old Oct 14, 2025 | 01:52 PM
007JB's Avatar
007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light
I had Portefield street pads for a year on my Vantage, (mainly wanted to get rid of dust) It was squeaking from day one, I've tried paste & hard braking.... nothing stopped the squeaks. Got rid of them, installed DFC 5000 series ceramic pads, no squeak at all.
Old Oct 15, 2025 | 05:23 AM
handyman2009's Avatar
Veteran: Canadian Forces
Funny I have been running Portefield pads for 10 years on my Vantage and never once they squeal, guess I am one of the lucky ones
Old Oct 15, 2025 | 07:02 AM
Matt(inMA)'s Avatar
Matt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud of
I'm a member of a Vantage group on FB and many have switched to Portefield pads to eliminate brake squeaking with great success. It's have a '23 Vantage with only ~5K miles but have not experienced any brake squeak. I suspect this is due to the low miles
Old Oct 15, 2025 | 07:57 PM
Davil's Avatar
Davil has a spectacular aura aboutDavil has a spectacular aura about
Mine don’t squeal. Porterfield make a few different types of pads. I suspect the squeal folk don’t have the same pads as us quiet folk.
Old Oct 16, 2025 | 06:51 AM
Marmot's Avatar
5 Year Member
Marmot has a spectacular aura aboutMarmot has a spectacular aura about
I had Porterfield's on my 2007, and haven't yet done the pads on the 2006 yet. Not to be pedantic but...the bedding in procedure for Porterfield pads is counter intuitive when compared to other performance pads. The first set I put on, I cooked bedding them in using the traditional method....and then I looked up their recommendations and realized what had happened to create the truly terrible squealing. The replacements were bedded properly and I used the orange goop on the back of the pads, no more issues.
Old Oct 16, 2025 | 01:13 PM
TonyN923's Avatar
TonyN923 is a jewel in the roughTonyN923 is a jewel in the roughTonyN923 is a jewel in the roughTonyN923 is a jewel in the rough
I went with Dynamic Friction Company low metallic low dust pad, no squeaks, very low dust, and same stopping feel. Pads on all 4 corners with E pads was right around 200, very affordable
Old Oct 20, 2025 | 01:31 PM
GWP's Avatar
GWP
5 Year Member
GWP is infamous around these parts
Switch your pads to Dynamic Friction. They perform great and your squeal will be gone. They're the only frictions I use on all my vehicles.
no1joey
Dec 13, 2015 11:55 AM
ciaka
Cayenne 955/957
Apr 29, 2013 11:41 PM
osj911
Cayenne 958
Apr 20, 2012 11:05 PM
onemanclique
Cayenne 955/957
Feb 16, 2010 10:16 PM
Project911
Oct 31, 2009 12:29 AM
