Best tire for CGT
For a car that heavy I would do Pilot Sport AS+. They stay stable under bigger, higher HP cars and don't wander much. Pirelli P-Zero Nero AS is a close second for the same reasons. It's dry traction is not quite up to the Michelin, but still pretty good. Do not be tempted to buy Continental DWS for this car. It's too heavy and you'll wear right through them.
Call me if I can help or you can order here!
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
damon@tirerack.com
Or use this link:
I have been a little hard on my tires and will need some before long please let me know what you get and how they do for you.
Thread bump, I'm about ready to do four tires and seeking information about them.
I have not been unhappy with the oem tires(P Zero Rosso) but is the B tire made for the Bentley any real difference than the non B tire? What is the advantage to the Pilot sport AS+?
Motivos? Why these?
I do appreciate good tread life but performance is supreme. I am used to the OEM Pirellis and would hate to go off road with a tire that did not grip as well as the originals. Money saved on tires would not equal the cost of a crash and repaint.
Ride comfort and road noise are secondary because most of the time i am not sport driving and like a luxury experience.
Tread wear that will go 20K is satisfactory.
I saw the Michelin Pilot Sport AS+ recommended above why not the Pilot Super Sport?
Motivos? Why these?
I am thinking a nice 20" wheel and tire set up for me would be perfect. 22s are for showing off plus they waste a lot of gas.
I have 20's and they provide a good ride/cosmetic balance. With the suspension set on sport II the ride is very flat with very little body roll so I think the stock suspension is up to the job. Actually it takes a lot of aggression to get the wheels to even slide a little. This darn thing really sticks like glue. It is easier to get tires noise from understeer on turn in than powering up off. Any elevation changes in the corners will multiply the tendency to break loose or dig in. Gotta love going into an uphill turn with good banking. WAO!
We a talking tight twists mostly in second gear pulling to the redline and then back down hard on the brakes for the next one. The tranny may shift up to third and I hate that because I have to reach for the pedal shifter to get second again. If redline is achieved in third the tires better not be sliding because your doing 90 mph.
Tires are for wearing out.
