Faut code Continental GT.
Old Aug 27, 2019 | 06:00 AM
  #61
BWings's Avatar
5 Year Member
BWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond repute
Originally Posted by Rico.Adams
Hi Steve ... An update on the break issue got the car on the ramp this morning all ok, no leaks all pipes ok, changed the fluid wasn't the right texture, all good now ...
Glad it is sorted Rico. Scary to step down on that pedal and get a flat response. Flushing brake fluid is high on my maintenance list. I do mine at most every two years, sometimes every year. Once the additives break down in the fluid the entire system is more suspect to contamination and corrosion. Modern fluids today probably can last more years than just two, but it is too easy to just flush it and start fresh sooner.
Best,
Old Aug 27, 2019 | 08:12 AM
  #62
Rico.Adams's Avatar
5 Year Member
Rico.Adams is infamous around these parts
Best,
Hey My Friend ... Im the same I usually do the same flush out the break fluid once a year on all cars and the antifreeze Lol we need antifreeze & wipers, when I use the wipers I think of your car & it makes me smile ... Yes your 100% correct these day the break fluid is a lot duralble & last longer but I just like changing it, maybe Im just old school ... I always go over the car every March ready for the spring but for some reason I over looked the break fluid this time ... Its all good mate ... Its still in the hight 20's here which is fabulous loving every minute ...
Old Aug 27, 2019 | 09:06 AM
  #63
BWings's Avatar
5 Year Member
Good philosophy Mr. Rico! Enjoy that beautiful weather. We're expecting 44*C today. At this temp. the air comes into your lungs HOT! Kind of takes your breath away.
Old Aug 27, 2019 | 09:11 AM
  #64
Rico.Adams's Avatar
5 Year Member
My God ... 44*c, if we in the UK got those kind of temps we would have a crisis on our hands ... take it easy my friend ...
Old Aug 27, 2019 | 09:22 AM
  #65
BWings's Avatar
5 Year Member
Will do...I just came back from a 20 mile bicycle ride. I do 60 miles a week, but at the crack of dawn. Then temps are usually only 32*C when the sun is just rising.
Old Aug 27, 2019 | 09:26 AM
  #66
Rico.Adams's Avatar
5 Year Member
Wow that is amazing Steve even at 32*c, I do ride a bike but not very often as my poor legs cant hack it anymore not to mention the rest of the body ... Lol
Old Sep 12, 2019 | 12:50 AM
  #67
yanacha's Avatar
yanacha is infamous around these parts
Hello friends, here is the change of the driver rating, after testing it works better, but I think one thing it is to stay for 1 month without rolling to connect to a maintenance battery charge, where all the lights are at maximum .
do you think that
little also come from the boot battery? since the service battery is replaced in December and startin batterie no
Old Sep 12, 2019 | 06:59 AM
  #68
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Are you asking, do you need to change your starter battery? I followed that you recently changed the main battery, and you can go one month without it being on the charger.
Please indicate what you are asking in regards to the photograph.
Merci bien.😉
Old Sep 12, 2019 | 07:51 AM
  #69
yanacha's Avatar
Hello,
I changed the electrical outlet as you told me, but I think I should have a lack of power. What is the function of the start up battery on the right side ? This is not a new one.
Old Sep 12, 2019 | 08:02 AM
  #70
5 Year Member
Originally Posted by yanacha
Hello,
This dedicated battery on the right side is used to start the car. Perhaps change that battery. Usually when the main battery is bad the starter battery is not far behind. Using a maintenance charger on the starter battery is a good idea if the car is not driven frequently.
The left battery is an AGM battery, maintained accordingly to AGM standards. The main battery can be charged through the charge port in the trunk. Verify if your battery is AGM. Some have put a standard battery [incorrectly] in substitution of an AGM.
The right side starter battery is a standard lead acid flood battery. This battery will require a direct conection to a maintenance charger.
Old Sep 12, 2019 | 08:18 AM
  #71
yanacha's Avatar
here are the pictures of the
battery and on the small pod there is a little oxidation.
Old Sep 12, 2019 | 08:25 AM
  #72
5 Year Member
So that's your starter battery which is a conventional acid flood battery.
Please try to explain what the difficulty is. You are having trouble getting the car started??
Merci
Old Sep 12, 2019 | 10:47 AM
  #73
BWings's Avatar
5 Year Member
Hello Yanacha,
I am not sure what problem you are having from your post. One comment though. The Bosch S4 is sized for an intermediate size car as it is too small for either side on a 2005 Bentley W12. I use Bosch and I have an S6 on the main side and an S5 for the starter battery.
Frank ( Sunnyside )
Bentley
Nov 15, 2025 05:13 AM
tonygt63
Bentley
Dec 23, 2023 12:02 PM
tomas valavicius
Bentley
Oct 28, 2023 02:08 PM
BentleyBob
Bentley
Feb 18, 2015 07:28 PM
pkoller7
Bentley
Jan 6, 2014 11:22 PM
