gt3 motor to a cayman?
Old Dec 16, 2011 | 06:00 PM
besiktas's Avatar
besiktas is infamous around these partsbesiktas is infamous around these parts
Anyone tried that?
Old Dec 16, 2011 | 06:27 PM
Cayman Cab S's Avatar
Cayman Cab S is infamous around these parts
Cheaper to buy a new GT3. I believe Btim has something cooking though.
Old Dec 16, 2011 | 11:22 PM
Fluid987's Avatar
Fluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond repute
Originally Posted by besiktas
Anyone tried that?
Yes, they call it a TPC and it beats up on the GT-3
Old Dec 17, 2011 | 01:53 PM
mach1pannu's Avatar
mach1pannu is infamous around these parts
This should give you some more info:
https://www.6speedonline.com/forums/...ne-cayman.html
Old Dec 17, 2011 | 03:02 PM
besiktas's Avatar
Couldn't find info on their site. Any links?
Old Dec 18, 2011 | 11:03 AM
kwiker's Avatar
kwiker is infamous around these parts
I think this is the thread you meant https://www.6speedonline.com/forums/...vs-997gt3.html
...and this is the "key post"
Originally Posted by 3.6L Boxster
The issue is that the GT3 engine uses the 964/993 crank. This has a different bolt pattern than the 996/986 line. The bellhousing on the 986/987/Cayman is too small for the 996/997 flywheel, but this isn't an issue with the 3.4/3.6/3.8 swaps as the flywheel from the Boxster/Cayman bolts up. So to use the GT3 you need a custom flywheel or modify the 996/997 trans by flipping the ring gear so you don't have 6 reverse gears. Don't know if this is possible but is was on the 915 trans when they were used in 914s.
The other issue is the integrated dry sump of the 964/993 based GT3 engine, this would require a bit of fabrication in order to relocate the oil tank away from the motor as it is mounted on the GT3 as there is no room.
So with all of the issues, plus the cost of a GT3 engine, seems to make more sense to just drop in the 3.8, especially if it is going to be a street car, now if it is a track car, the GT3 conversion might make sense.
Todd
Old Dec 19, 2011 | 06:46 PM
besiktas's Avatar
I was thinking about a cayman with a stroked 4.0 gt3 motor with around 500 hp or 4,0 turbo motor around 600 hp, sequential transmission, all the necessary suspension stuff and around 2200 lbs exclusively for track. anybody did anything like that before? sounds good to me, but?
Old Dec 19, 2011 | 08:02 PM
GTgears's Avatar
GTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond repute
It was done by Jurgen Alzen Motorsports and competed in GT4 class in Europe several years back. We're also currently affiliated with a similar project that is well on it's way. In fact, the engine and gearbox were test fit just last week. But I'm not in a position to reveal any more details or pictures until the owner of the vehicle decides he wants it made public.
Though what is public and easy to find is the BGB 3.8l 997 Carrera S DFI swaps that have recently been done in their two retired Grand Am Caymans. Look around this forum a bit and youtube and you'll find these monster cars. For something cost effective and pretty damn close to "bolt in" an X51 DFI 997 engine is hard to argue with.
The first car mentioned will be upwards of $200-250k when it's all said and done. The BGB cars are being done for half that. Either way, such a project is not for someone who has any concerns about resale value or isn't willing to open their checkbook wide open. The BGB cars were so expensive because they were done on Grand Am racecars that already had 6 figures into them. But for someone with a 2009 DFI Cayman S, a 3.8l 997 swap could actually be done without taking out a second mortgage or robbing your kid's college fund.
Old Dec 21, 2011 | 07:17 PM
besiktas's Avatar
FVD did a 3.8 carrera dfi engine to a cayman for 25k euros including the engine. I can not see how that would cost $200 - $250k. With all due respect, that sounds ridicilous to me.
Anyway, I have a spare 997 Turbo engine I may be willing to reinforce with a 4 liter stroker with a pair of GT series turbos and put in a Cayman. Any ideas? I don't like the DFI engines, because they are garbage to me next to a GT1 block.
Old Dec 21, 2011 | 07:36 PM
GT 3 engine is entirely different from the 3.8 dfi, $50K difference. Then you have to make it work in a 987, as others have stated, the bell housing won't match with the GT 3, but mates right up with the 3.8. Do more searches on Planet-9.com.
Old Dec 21, 2011 | 07:43 PM
GTgears's Avatar
Right along the lines of what I was about to say. As I alluded to in my post above there's more than one way to skin a cat. I can take a 2006 Cayman S and throw in a 2006 997 Carrera engine and have a $50-60K hot rod including the cost of the car.
But when I'm talking the numbers I mention above we're talking a new 997 Cup Car crate engine with Motec and crate sequential gearbox. You're in for $125-150k right there. And you haven't even started the fabrication to make it fit, or any brake or suspension work, or a cage, or any sort of body work. Building a Cayman into a racecar that can run toe to toe with a 997 Cup Car for $200-250k is pretty easy to do. And by easy I mean it's easy to spend that much money, not that actually building the car is easy. Building it is not. Writing the check is the easy part...
Old Dec 22, 2011 | 11:30 AM
Byprodriver's Avatar
Byprodriver is infamous around these parts
Then there's that little detail of learning how to actually be able to use that much power without killing yourself or others.
Old Dec 24, 2011 | 11:19 PM
Steve Theodore's Avatar
Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !
Holy cow...it's nice to actually see some hard numbers about this dream swap. I daydream about this type of swap all day, and stuff like this serves as an appropriate reality check for sure.
mikerosi
Dec 6, 2018 06:23 PM
orbelo
Aug 30, 2015 12:26 PM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
