Rattle in the back
Old Dec 13, 2013 | 07:15 PM
Michael Yount's Avatar
Michael Yount is just really niceMichael Yount is just really niceMichael Yount is just really niceMichael Yount is just really nice
Rattle in the back
Before I run to the dealer and seek a warranty fix -- got a 2010 Cayman S with about 17k miles on it. VERY easy life so far. Lightly optioned - does have the 19" combo. I've got a very persistent rattle back behind the passenger compartment somewhere. Relatively low frequency (as rattles go) - just about any bump the rear suspension hits generates the noise. Sounds like something is actually loose --- anyone had anything similar? Driving me crazy - and I don't see anything obvious under the hatch. Have done a good bit of checking/shaking/etc. to try and replicate it when the car's parked - all with no luck. Haven't been under the car yet. Placing rear spoiler in up position has no effect.
Old Jan 8, 2014 | 01:40 PM
ffarr1's Avatar
ffarr1 is infamous around these parts
clunk in the trunk syndrome
if you go to Planet9 there is are several discussions about this!
Old Jan 8, 2014 | 02:12 PM
Eventually discovered that - and at the Cayman Registry. Added some felt in the right spot and adjusted the rear hatch stops -- quiet as a mouse. Well, more like a cat stalking a really quiet mouse.
Old Jan 9, 2014 | 02:22 PM
DennisP's Avatar
DennisP is infamous around these partsDennisP is infamous around these parts
I just backed my rear hatch stops out 1 turn and mine stopped creaking.
Old Mar 4, 2014 | 08:12 AM
skeeler's Avatar
skeeler is infamous around these partsskeeler is infamous around these parts
Oh man.....glad I ran across this! I am going through the same thing with 2010 Cayman S, driving me crazy!!!! So it is actually the rear hatch/stops that need to be adjusted?
Old Mar 4, 2014 | 09:14 AM
DennisP's Avatar
I believe that with time, the rubber compresses and loses some of its elasticity, sort of like your running shoes after you've ran several hundred miles in them. Backing them out a little compensates for that. Some people add felt as an added measure, mine didn't require it. Best of luck.
Old Mar 4, 2014 | 09:26 AM
skeeler's Avatar
Good to know! I really thought I had some suspension issues to work out.....but it has been so cold here, I was waiting until Spring to address it. Hopefully this should take care of it! Thanks again!
Old Mar 7, 2014 | 03:21 PM
mlbraptor's Avatar
mlbraptor is infamous around these parts
Can someone take a picture of the area where the fix is needed.
97GtsMonster
Nov 17, 2015 12:38 PM
su_maverick
Sep 15, 2015 02:57 AM
raaspaza
Bentley
11
Sep 9, 2015 08:51 AM
New991S
Aug 31, 2015 05:22 PM
shinjuku
Aug 29, 2015 09:59 PM
