Cool things you may not have known about your Cayenne...
Try it on your Cayenne. I did and it didn't work. I actually bought the module first, then saw a post about just shutting off the regulator, thought I just purchased an item I didn't really need. So I tried it and it didn't work, thought went back to..... cool I got the module.
The intended purpose is to stop the truck from auto-leveling when jacking up the vehicle to change a spare. Believe it or not, the truck will "adjust its weight" if you try to jack it up without locking the air suspension- even with the ignition off.
Very scary since it trys to move off the jack
With that said, you have to watch the instrument cluster very carefully for the notification that it is off or on. The notification is so subtle that you can miss it (especially if you have other alerts .. like bulb out, tire pressure, etc). I think there is an audible beep on lock, but no beep on unlock.
Go figure.
EDIT: I should also add that it will lock in ANY position. So when I am changing a tire, I lock in the "loading setting". I plan on locking the setting in terrain when the snow is unbearably high for clearance. Note that this is dangerous and you could roll over if you drive too fast.
...where exactly are these buttons?
...and if you are in reverse, you can adjust where the pass mirror will change too when reversing (manual says to put park brake on for adjustment).
If the side mirror control button is turned to the passenger mirror, when you put the shift lever in reverse the passenger mirror will turn downward to see the ground area when backing up,then return to normal position when driving, the mirror can be programmed how far to turn down with a similar seat memory position function described in the manual.
...lol. I hope you throw it out after you 'go through the whole thing's.
As far as the reverse function of the mirrors - you can have them both swing down at the same time if you set it up on the wiper stalk. I think it's under Settings - Comfort - or something like that. And while it's in reverse you can store the settings in the seat memory for the mirrors - and on the key! It's in the manual.
This thread is GREAT!
FWIW - I too learned after 3 months that the back glass hatch could be opened. But good luck opening the cargo cover only through that hatch!
The newer models have this button.
What year is your C ? If it's a 995 - 03'-06' start your car, go to the main menu on the instrument gauge, squeeze the bottom button on the right lever directly behind the wheel, use the end of the lever for up and down and scroll down to settings, click bottom button, scroll down to comfort, sselect alarm and then uncheck the box saying interior and/or angle. Use this same method for activating your alarm to sound when locking your doors, you can select one click to unlock all at once or driver only with 2 clicks for all. I've owned my CTT for 8 years and sitting at a draw bridge on day I started to mess with it, I never knew what main menu was for
I can verify that the "regulation off" for locked suspension does work since I use it about once a month in the 958.
Go figure.
Go figure.
I haven't tried it but my manual does say that you can do this. My ctt is an 05.
I think people have an easier time reading via a medium they enjoy going to, rather than opening up a manual to lear this. So in effect, this forum serves the purpose it was intended to fulfill (help educate those interested in the topic - Cayenne).
many things i already knew (some of them are really obvious), some i didn't.
Not sure I read this...but here we go :
If you press 'REST" button (different loction for "11+) after key removed from ignition , the hot air will still push for about 25 minutes.
On the "11+, this feature works with the A/C too.
So if it is too hot or too cold outisde, and you do a little stop, this could be very usefull.
