Engine rear main seal replacement
Old May 4, 2018 | 07:12 AM
2fast2stop's Avatar
2fast2stop is infamous around these parts
Is it any more difficult to do than other AWD vehicles when pulling the trans/t-case? Can everything on the required components be unplugged without messing up any programming? Any words of wisdom from someone that has done this before I dive in?
Old May 7, 2018 | 01:03 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
Which engine?
Old May 7, 2018 | 02:12 PM
2fast2stop's Avatar
The 4.5 v8
Old May 7, 2018 | 06:18 PM
In the case of the 958 V8 - the replacement of the rear-main-seal calls for engine/transmission/TC removal - all for a $33 seal.
As far as I can tell - the same is true for your 955/V8. Illustrations show many bolts holding them together - that would only be accessible with the assembly removed from the vehicle.
Old May 7, 2018 | 06:38 PM
2fast2stop's Avatar
Wonderful. Solid engineering at it's best. These really become throw away vehicles as they age unless you can tackle anything yourself. Thanks for the info
Old May 8, 2018 | 10:49 PM
LAPorscheGuy's Avatar
LAPorscheGuy is infamous around these parts
You can do job with engine still in car. Does require some special tools for the torque converter bolts.
How many miles does it have?
Old May 12, 2018 | 04:40 PM
Please tell more.. I'm facing this on my '11 Turbo.. it's dribbling out the weep hole for the torque-converter housing. Looks like engine oil.
Old May 13, 2018 | 11:13 AM
Hhhmmm, don't think I've done an 11' ... It's a different drivetrain, but should be same idea. Wish I had more for ya!
carbonissimo
Oct 1, 2004 06:42 AM
Greyghost
Dec 19, 2003 04:12 PM
Ken7258
Dec 1, 2003 07:51 PM
nova996
Nov 20, 2003 06:06 PM
