EVO Big Turbo Cayenne TT Project
I have a CTT with fabspeed bypass pipes with no exhaust just straight pipes and a GIAC chip. I took it to the track and the best i ran was a 14 flat.
What's up?
I feel this truck is way faster then my e46 M3 and i ran a 13.4 in that.
What's wrong with my beast? Is it me?
What's up?
What's up?
What's up?
It could be a lot of things.
What's up?
What's up?
Evan
Originally Posted by AMG ETR
Daymn, I ran a 13.4 WITH 22's!! Somthin is up! Even my worst run the first one with PSM ON and just flooring the pedal was a 13.9!
Evan
Evan
Originally Posted by Evo650
Don't leave me hanging. How?
I did a very slight boost launch (holding brake and gas) in tip mode with PSM off for my best run. However I hit rev limiter shifting 2nd and 3rd which slowed me a good bit. I bet a on a perfect run with a good launch I could run 13 flat even with the 22's and maybe very high 12's with some lighter rims
Evan
.Evan
Originally Posted by sharkster
There's a few tricks etc... and I'd need to go play with one for a while first to remember the balance/naunces between bogging and hooking in that thing correctly first...
How do you recommend launching? Also, I have 20" Champion wheels on the truck because thay're much lighter than stock. Is there any real advantage to going smaller even if the weight savings is minimal?
What was your 60' time and your trap speed? Are you running on 22's? Where's the track and what were the temps?
Think it could be my straight pipes? I also have a 200 pound stereo system in it.
Evan
.Evan
Something is wrong here..I'm going to go back tomorrow.
WOW evan! I tried tip the first 2 runs and i kept hitting the limiter from 1st to 2nd. I ran a 14.6 with the tip. Then i just did it with PSM off in auto and i ran the 14flat.
Let us know how it goes!
Evan
PS- Shoot me your email when you get a chance, would like to chat!
My runs were in 85 degree weather, high humidity, full tank of gas, 22's, hit the limiter, etc..... Bascially I had everything going against me even for my 13.4!
Evan
Evan
Wow, i must just suck at driving.
I will keep u updated on tomorrow's times.
My email is nocsk8shop@gmail.com
peace
Evan
Evan
It's just me, getting use to launching this big beast.peace
When is this kit available for the cayenne?
