Code P1031 "Reduced Engine Power"
Old Nov 14, 2019 | 09:27 AM
Mazurda's Avatar
Mazurda is infamous around these parts
I see this is a pretty common thing across the board, Is there an air fuel ratio sensor to replace? Or the high fuel pressure pump is the only fix? Along with fuel sender and sensor? Not sure where to start. I noticed an odd burning plastic smell last night and got this error this morning. Want to make sure I am addressing the right issue correctly. Thanks in advance guys
Old Nov 14, 2019 | 12:40 PM
Mazurda's Avatar
Anyone?
Old Nov 14, 2019 | 01:41 PM
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
Originally Posted by Mazurda
Anyone?
Wish I had an answer for you my friend...
(I'm at Walmart, just picked up my Unity strut)...
Old Nov 17, 2019 | 04:44 PM
NormalFellow's Avatar
NormalFellow is infamous around these parts
Run the codes with a scanner... However, in your case, open up the oil cap, and take sniff to see if you smell fuel in there...
Old Nov 18, 2019 | 03:14 AM
OEkun1's Avatar
OEkun1 has a spectacular aura aboutOEkun1 has a spectacular aura aboutOEkun1 has a spectacular aura about
The high pressure pump is on my list to change as I've experienced the same code. I don't drive the car as often as I would like but its definitely on the list of things to do asap.
Old Nov 21, 2019 | 10:50 AM
Hey Guys, Before ya'll start replacing your HPFP for no reason, please please check out this Informational Bulletin in regards to this specific issue.... In short, check your HPFP Sensor first, under the intake manifold before you go out replacing your HPFP, especially if you pop yoir oil cap and dont smell clear signs of Gasoline. Please check it out...
Vehicle: All Technical Service Bulletins Fuel System * Unnecessary HP Fuel Pump Replacement Quick Info 2 55/11 ENU 2463
2010 Porsche Boxster (987) F6*2.9L
Copyright ? 2013, ALLDATA
10.52SS
Page 1
Quick Info 2
55/11
ENU
2463
July 8, 2011
The present document was valid at the time of print. A later version may be available online
Unnecessary Replacement of High*Pressure Fuel Pump (55/11)
Model year: as of 2009 up to 2011
Information
^ Document with limited validity
This Quick Information is valid until December 31, 2011
Vehicle Type:
Boxster/Cayman (987) model line
Carrera (997) model line
Cayenne (92A) model line
Panamera (970) model line
Concerns:
High*pressure fuel pump
Information:
We have discovered that the high*pressure pump is increasingly being replaced, but in subsequent tests carried out by the manufacturer,
these high*pressure pumps are found to be functioning correctly.
Due to various customer complaints, such as
^ engine start problems
^ reduced engine power
and the following fault memory entries in the DME control unit
^ P0190 * Fuel high*pressure sensor
^ P1030 * Fuel high*pressure sensor stuck
the high*pressure pump is being replaced (complaints can vary and problems can occur independently of each other).
In most cases, the sensor of the high*pressure pump is defective and is the cause of these complaints.
Action Required:
Diagnose the faults and work through the fault codes using "Guided Fault Finding" in PIWIS Tester II.
Model year as of 2009, Model year up to 2011
C02, C36
Old Dec 15, 2019 | 04:23 PM
OEkun1's Avatar
10.52SS
Page 1
Quick Info 2
55/11
ENU
2463
July 8, 2011
Information
Vehicle Type:
Concerns:
Information:
Action Required:
C02, C36
Mine is on order...will be changing soon...hope this addresses the issue
Old Dec 16, 2019 | 11:57 AM
Mazurda's Avatar
All good after changing pump. should be same for you. good luck
0zzy997
Bentley
16
Feb 16, 2017 11:06 AM
ratedg37
Sep 21, 2016 04:29 PM
andrewgt3
Jul 22, 2013 05:58 PM
Moss1st
Cayenne 958
Sep 22, 2012 11:34 PM
mcnatprice
Nov 8, 2011 06:36 PM
