2012-14 V8 Vantage Manual Reliability
Old 06-15-2019, 10:09 AM
carnatic2c's Avatar
carnatic2c is an unknown quantity at this point
On the market for a '12 to '14 v8 vantage 6spd stick shift with around 5k to 15k miles, so low miles. I know about the 3 yr bumper to bumper extended warranty, but with these later cars is reliability (clutch life, sensors, etc.) good? This will be a weekend car mostly and I don't wan to be spending time at the dealership. Thanks!!!
Old 06-17-2019, 11:27 PM
007JB's Avatar
007JB has a spectacular aura about007JB has a spectacular aura about007JB has a spectacular aura about
I have 2013 V8 with 6 speed manual, no problems so far 8K miles, very reliable car, I drive mostly on weekends . 6 speed is the way to go. good luck with search. they're little harder to find than sport shift cars, but I'm sure you'll find it.
Old 06-18-2019, 07:10 AM
Dalecannavan's Avatar
Dalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to behold
I have a 2012 Vantage S with 20k on the clock. The biggest item repaired under warranty was replacement of the rear lights for condensation. Otherwise I’ve only had to do annual services.
Old 06-18-2019, 07:13 AM
brightoncorgi's Avatar
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
They're as reliable as a 911 FWIW.
Old 06-18-2019, 08:47 AM
papigko's Avatar
papigko is a glorious beacon of lightpapigko is a glorious beacon of lightpapigko is a glorious beacon of lightpapigko is a glorious beacon of lightpapigko is a glorious beacon of light
I have a 2012 vantage 6speed. it has 39,000 miles on it including multiple track events. The only problem it has had was about 4 yrs ago it had condensation in one of the tail lights. This was fixed under warranty. I dropped the extended warranty after the first yr and am quite happy I did. The only other issue which is mostly associated with daily driving is the leather on the dash shrinks and I had to have some of the panels redone at a staggering cost of $100 from a local interior shop and I replaced the piano black waterfall due to some mild cracking. Otherwise its been a rock solid car don't hesitate buy one
Old 07-01-2019, 06:00 PM
dsvantage's Avatar
dsvantage is on a distinguished road
The clutch on my 2009 manual started slipping badly at around 25,000 miles, and I couldn't use most of the power without the RPM shooting up and going nowhere for it. No idea how aggressively the previous owners drove it but the dealer said that time frame is not unusual. I installed the uprated, dual plate AMR clutch instead and it's a completely different car. IMO this is the clutch the car should have come with. It grabs much sooner and towards the bottom of the pedal range so it took some getting used to but it's like a new car and should last longer too. Well worth the slight premium if you do have to replace yours.
Old 07-02-2019, 10:36 AM
RolexDaytona1's Avatar
RolexDaytona1 has a spectacular aura aboutRolexDaytona1 has a spectacular aura aboutRolexDaytona1 has a spectacular aura about
If you powershift your vantage... you will need a clutch in 20k miles. If you drive it like you did not steal it... clutches will last a long time.
2006, 80k miles. Daily driven for the last 6yrs by me... Prior two owners were 'adults'... I drive fast but not with the intent of hurting the car..
VERY reliable car... Usual things people note.. headlight/taillight failures, leather dash shrinkage.
Occasionally people do get an oddball big problem, but that can happen with any car.
Basic maintenance, plugs at 70k, fluids as usual. No timing belt service (chain). Excellent exotic to maintain.
Old 07-02-2019, 01:29 PM
Hybrid's Avatar
Hybrid will become famous soon enoughHybrid will become famous soon enough
Just for perspective, if you beat the hell out of your cars, the Vantage can be a little pricey, but so is a 911!
New engine = $42K (rebuild = $15K)
New Transaxle = $22K (rebuild = $6K)
Replace stock clutch with twin clutch + AMR flywheel = $5K
ArnoldK.
01-23-2022 05:44 AM
Vekto911
05-28-2017 12:03 PM
MrNurse
11-25-2013 05:39 PM
Suspence8
06-01-2013 06:16 AM
acf
11-29-2012 08:57 AM
Quick Reply: 2012-14 V8 Vantage Manual Reliability
