More Boost Controller issues ... help
Old Nov 24, 2009 | 08:00 AM
bmoores's Avatar
bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !
Ok, so since the mile I've had issues with my boost controller. I haven't really been driving the car much so its an issue i'm only really getting too deal with now. At first it was determined the solenoid may be bad, we replaced it and no improvement. Boost controller would not show above .75 bar. Last night Mr. Powell was kind enough to let me have his spare controller in addition to the Solenoid he had already given me to try. With the new controller the car now boosts 1.4 bar regardless of how high or low I set the boost. The car has ZERO boost leaks. I'm thinking I might just need to get a brand new Controller and Solenoid (which I actually received yesterday). It is puzzling me though that both controllers would be bad.
Any thoughts?
Also,
The wiring has been check for continuity etc. Everything is good on that end.
Old Nov 24, 2009 | 08:04 AM
WOODTSTER's Avatar
New Controller and solenoid sir. Then it should work.
Old Nov 24, 2009 | 08:10 AM
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
Is there anyway to reset the preferences on the Profec B? I seriously think the reason why it is acting up now is because I had it configured for a External Wastegate setup. Both of those parts worked flawlessly before I took them off the car. I do know on the HKS unit I had to specify Externals when I set it up.
Good luck on figuring it out Ben! I know how it feels when you can't be out boosting in this weather!
Old Nov 24, 2009 | 08:15 AM
bmoores's Avatar
Thanks guys. I guess i'll track down a controller and install the fresh Solenoid and see where that gets us.
Old Nov 24, 2009 | 08:17 AM
ttboost's Avatar
MOST EBC"s need to be configured for internal or external waste gates.
ttboost's Avatar
or you could just let Porsche control it
Old Nov 24, 2009 | 08:36 AM
bmoores's Avatar
Thats too easy Mike I like making life difficult!
Can anyone chime in one whether or not the Profec II can be configured for externally gated cars vs. stock configuration?
Old Nov 24, 2009 | 09:42 AM
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
The "setup" for external wastegates is a different routing of the vacuum tubing.
https://www.6speedonline.com/forums/...tegates-2.html
Have you tried running it off? It will work as a nice peak boost / boost gauge.
I would:
1) run it off, you should be riding your wastegate(s). If it is not then you have a electrical or mechanical failure / bad install. Look for a pinched line to the head unit, or the wrong ports plugged / hooked up.
2) If 1) results in a wastegate boost level then reset the greddy to stock and retune it using this guide:
http://forums.evolutionm.net/evo-how...b-spec-ii.html
Look for markski's guide here for the proper setup for internal wastegates:
https://www.6speedonline.com/forums/...ontroller.html
I am getting ready to go to external wastegates this winter, and have been doing some research.
Tom
Old Nov 24, 2009 | 10:25 AM
bmoores's Avatar
Tom,
I really appreciate your post. I've got through the above actually using the exact links you provided. I just wanted to be sure there was no setting on the controller itself outside of wiring that was dictated specifically for external vs. internal.
It's definitely a combo of bad controller/solenoid.
Old Nov 24, 2009 | 11:07 AM
ttboost's Avatar
Tom,
It seems I recall my HKS EVC IV had an internal/external switch? Did you make sure there are no dip switches on the back or bottom for this?
Old Nov 24, 2009 | 03:09 PM
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
I'm running the same controller on mine and it works fine.
It just needs to be routed differently the hoses Markski is a Master at the install.
Old Nov 24, 2009 | 03:15 PM
No switches its a simple hookup.
Old Nov 24, 2009 | 03:26 PM
bmoores's Avatar
Thanks Corey
Old Nov 25, 2009 | 10:36 AM
unvmy996's Avatar
B , im also running externals , there is not switch on the profec for internal /external gates, like corey said , the only diff is the lines thats it , and you will have play with the setgain a bit , but that should have nothing to do with the issue your having .
give markski a jingle he will help you out .
Old Nov 25, 2009 | 10:45 AM
Powell's Avatar
Ben, Steve should be calling you. I remember I had the EXACT same issue, and I don't know why it didn't click to me. He's going to have you test a few things. I ended up having to get a new reference from the Y-Pipe for the Boost Solenoid. Because of that problem that I swapped to External Wastegates hoping it would do something. Then I retapped that Y-Pipe and it fixed EVERYTHING! Hopefully that is the case for you.
Jul 29, 2019 11:13 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
orbelo
Aug 30, 2015 12:26 PM
markski@markskituning
Aug 24, 2015 10:07 AM
TrackOne
Aug 20, 2015 12:56 PM
