MadeThe Move To K16/16g Billets From Tony At EPL
Old Nov 22, 2013 | 06:23 PM
  #196
stilov's Avatar
stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !
I always thought the risk of bov on maf cars is that the air being let out is already measured and the dme calculates the fuel as if that air was included.
I thought that's why you end up rich.
Old Nov 22, 2013 | 06:26 PM
  #197
TabooPc's Avatar
TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !
That is why. I don't think letting the air out faster is a solution...
Old Nov 23, 2013 | 12:18 AM
  #198
GT996's Avatar
GT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond repute
Originally Posted by 996tt550hp
Well tried to take some video cant hold the camera lol to much torque. It now hits way early also they have to fix that small intake leak but since its a pain im going to buy the EVOM turbo inlets.
Good to hear. Let's look at a new log again. This will tell everything.
Old Nov 23, 2013 | 12:48 PM
  #199
'02996ttx50's Avatar
it is also possible your car is fine but you are suffering the automotive equivalent of "Münchausen syndrome" lol
Old Nov 23, 2013 | 01:26 PM
  #200
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
Lol second gear is like spins all the way and thurd spins and catches at 5k i like when my turbos spooled later lol mayve its becayse its 49 degrees down here.
And 20" wheels.......
Old Nov 23, 2013 | 01:28 PM
  #201
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
No i can vouch on that my 18s and 19s spun way worst when i had just 16gs. Another to remember im already around in the range of 550whp at just 1.1 bars i dont know if Tony will let me go higher i will probably do injectors next so i can max these turbos out.
Old Nov 23, 2013 | 01:41 PM
  #202
Not sure how since 18" & 19" tires will have more sidewall,
therefore,more rubber between the rim & the ground to flex before spinning. The larger the rims the smaller amount of tire sidewall the greater chance of spinning(e.g. 20" rims)
Or you have old tires which have hardened over time & are less effective.
Old Nov 23, 2013 | 01:45 PM
  #203
996tt550hp's Avatar
I am sure your right at that. 20s just seem nicer lol I might get a set of 19s again.
For everyone helping thanks so much this was not easy just old vacuum hoses busting lol.
Old Nov 23, 2013 | 02:02 PM
  #204
pwdrhound's Avatar
An 18" wheel with a larger diameter tire like a 305/35/18 (26.4") will provide optimum performance. A 19" with a 305/30/19 (26.3") is not quite as good but decent. 20" wheels will be worse due to the limited sidewall height and heavy wheel mass. Look at Cup cars. There is a reason they run 18s with relatively skinny but tall tires, even taller in the rear.
Out of curiosity, I had the car out today and while on the hwy I grabbed my iPhone and took a video of the tachometer to see where my turbos are boosting at relative to RPM. This is easy to do in 5th if you start at 2500 and just mash the gas. I let up at about 4000rpm which takes you to just a shade over 100mph to keep things safe. I looked at the video frame by frame on the iPhone and this is what I get on RUF K24s:
2600 0.2bar
2800 0.4bar
3000 0.6bar
3200 0.9bar
3500 1.3bar
Past 3500 it stays at 1.3 bar. Can you do this so we can get an idea of the performance of your K16? Like I said, do it in 5th. 3rd or 4th is useless as everything happens too fast and the gauge can't keep up.
Old Nov 23, 2013 | 02:18 PM
  #205
Lol second gear is like spins all the way and third spins and catches at 5k i like when my turbos spooled later lol mayve its becayse its 49 degrees down here.
i also noticed you're "rollin on 20's" ( lol sorry ) how's the wheel hop with those? i'd ask "why"? but you seem to know what youre doing ..and yeah..all of our cars are running better the last few weeks i would imagine. mine sure is
Whatever happened no i spool to early lol around 3500 RPM.
are you saying your car doesn't boost? at all.. or hit FULL boost until 3500 ?? /confused
Old Nov 23, 2013 | 02:29 PM
  #206
996tt550hp's Avatar
Third gear fully boost right about there 4th is a little higher like 3900 and not really any wheel hop sometimes spin in second.
Old Nov 23, 2013 | 02:32 PM
  #207
seems well within acceptable range(s). sounds like you've got it sussed!
Old Nov 23, 2013 | 02:34 PM
  #208
996tt550hp's Avatar
I think so lol the power is unreal it hits so hard one little intake leak i need to take care of. I will do some more videos.
Old Nov 23, 2013 | 02:56 PM
  #209
pwdrhound's Avatar
There you go:
http://www.youtube.com/watch?v=PKmsH...ature=youtu.be
I am boosting at 1.3bar at 3500 rpm in 5th gear with K24 hybrids. You say you are at 1.1bar full boost at 3900 in 4th gear with K16 billets? I would love to see a video of your car in 5th starting at 2500 rpm. I'd say something is not right. K16/hybrids/16g/billets/whatever should be boosting quicker than K24s unless you have restrictive intake piping, exhaust, or some other issue.
Old Nov 23, 2013 | 03:00 PM
  #210
996tt550hp's Avatar
Topspeed said the car is running perfectly when they drove it and boosting exactly where its supposed too. Ill take a video maybe today its real cold out right now.
