MadeThe Move To K16/16g Billets From Tony At EPL
Intake is your problem. Put your stock airbox and filter back in, you will never know the difference and all your problems will go away. If you chose not to, buy 3 or 4 MAF's at a time,because you will use them up...
My car made almost 600whp with all stock intake piping, IC's and airbox...with original MAF. Never blew one.
You should see full boost from a K16 frame turbo under 4000rpm, might want to run a leak check and make sure the gates aren't swinging open early.
On another note, if you're making the power to push your car to a sub 7 sec 60-130, you're on borrowed time with a 5 bar, IMHO. Highly recommend you get a durametric hooked up and check AFRs and injector duty cycles.
Good point i am running what he told me i cant go any higher until i get injectors. Ya there is no way im getting full boost at 4k maybe 4.5k to 5k but im still on stock wastegates to protect the fuel so i dont overboost also i just found out my MAF blew again lol well i cleaned it will see.
Ok so i have looked at the dyno graphs from AMS and now i see our full boost kicks in right at 4k rpms but our power doesnt fully get there until 4800k to 5k rpms......
Also im not sure if Tony does Mafless tunes?
Ok Earl you are right heres what i did.........
With the MAF connected i did some runs then after that i got a code P0175 and P0172 (Rich Condition both banks) and it lags big time when i punch it at 4k RPM the turbos dont spool until 5k RPM. I have serious turbo lag.
Well i just took the MAF connection off and heres the result.......
So far no codes except MAF low voltage because its disconnected also when flooring it no turbo lag when i hit it at 4k RPM it spools up all the way to redline no turbo lag.
Ok so do i have a bad MAF? i asked him to raise my idle to 800 RPM because of flywheel.
Maf has nothing to do with wot the 02s take over open loop but geres the thing this is annoying now the same thing with the maf sensor off when i rev it up it hesitates this is odd i can take a video. I think i hear soemthing by the TB like hissing sound.
Flirting with disaster, but do what you want.
Regarding your hissing noise...Check this?
https://www.6speedonline.com/forums/996-turbo-gt2/192392-my-p-0507-fault-code-has-been-solved.html
This is interested my maf back on wow i know tony brought my idle to 800rpm but i get the hesitation and stumbke just like u but different codes.
