What is this thing and why is it leaking....
Old May 8, 2014 | 03:09 PM
Byron in Atlanta's Avatar
Byron in Atlanta is a splendid one to beholdByron in Atlanta is a splendid one to beholdByron in Atlanta is a splendid one to beholdByron in Atlanta is a splendid one to beholdByron in Atlanta is a splendid one to beholdByron in Atlanta is a splendid one to beholdByron in Atlanta is a splendid one to beholdByron in Atlanta is a splendid one to behold
brake fluid into my front trunk?!? It is located just under the master cylinder and the black hose that comes from the reservoir is leaking brake fluid just as it enters this contraption. Seems to be the fitting or white piece at the end of the black tube that is leaking. What is this thing and what does it do? Can I replace the fitting or do I need a whole new thingy?
Old May 8, 2014 | 05:48 PM
pwdrhound's Avatar
What you see under the brake master cylinder is the PSM pump. Whenever the pump activates it draws brake fluid through the black plastic tube from the brake fluid reservoir. The black line includes the white fitting and is sold as a whole (part number 99635532341).
The white fitting on the black line plugs into an adapter (part number 99635563540) which is screwed into the PSM pump. Both items are about $25 each.
Old May 8, 2014 | 07:48 PM
Thanks Pwdrhound....Is changing them pretty straightforward? Someone on RT mentioned that you may need the PIWIS system to properly bleed.
Old May 8, 2014 | 08:35 PM
pwdrhound's Avatar
You will most likely need PIWIS to cycle the pump as you will introduce air into the system during the swap. The swap is straight forward, yes. You will first need to bleed the fluid out of the reservoir and then swap the line.
Old May 9, 2014 | 09:20 AM
anikzad's Avatar
anikzad is a name known to allanikzad is a name known to allanikzad is a name known to allanikzad is a name known to allanikzad is a name known to allanikzad is a name known to all
Or perhaps Durametric since I understand it has a similar functionality.
Old May 9, 2014 | 09:23 AM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
Good info!
Old May 9, 2014 | 09:31 AM
pwdrhound's Avatar
The latest version is supposed to allow you to cycle the PSM and ABS pump but I never tried using it. Give it a shot
Old May 9, 2014 | 11:21 AM
I figured this might be a good excuse for me to acquire a Durametric, but I use a Mac computer!
Old May 9, 2014 | 11:46 AM
wross996TT's Avatar
No problem, just run bootcamp or Parallels and you can use durametric...I do.
Old May 16, 2014 | 09:21 PM
Ordered the tube last week. The dealership told me 2-3 days. So I called yesterday to see if it was in yet and was told it would be 2-3 weeks as it was coming out of Germany!! Thanks for the heads up guys.
Old May 17, 2014 | 06:23 AM
jpflip's Avatar
I used parallel on a Macbook Pro and it work perfectly!
Old May 17, 2014 | 07:08 AM
thomapa1's Avatar
thomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of light
FYI - Try a few other sources for parts vs dealer
Auto Atlanta - http://www.autoatlanta.com/
Good parts lookup diagrams
Suncoast Parts - https://www.suncoastparts.com/
(I'm sure there are others)
Old May 17, 2014 | 12:26 PM
pwdrhound's Avatar
Tell them to Fedex it. 2-3 days from Germany. That's what my dealer does...
Old May 18, 2014 | 10:49 AM
Yeah, I paid the expedite fee. I was just disappointed that they didn't call me when they realized it was not in the states! They said no dealership in US showed one in stock.
Old Jul 17, 2014 | 07:48 PM
Update....the black hose with the white end was not leaking, rather it was the quick connector in the brass fitting. When the parts guy looked it up, he thought both parts came with the tube. I told him that I didn't think the brass fitting was included, and even gave him the part number, but he talked me out of it as there was not one showing in their system even in Germany. The thing took 3 more weeks to finally show up, by which time I had blown up my engine! I put the parts in yesterday and the leak is gone!
hdc4
Bentley
11
Jan 6, 2019 07:17 AM
NorthWiking
Sep 21, 2015 02:22 PM
UAE991
Sep 11, 2015 06:04 PM
kensilver
Sep 11, 2015 12:29 AM
AM v12v
Sep 4, 2015 02:52 AM
