Water pump popped
Old Jan 25, 2018 | 12:49 PM
Mpsuk's Avatar
Mpsuk is infamous around these parts
Water pump popped
Water pump failed yesterday. Mechanic said, while he is there, he might as well do coil pack and plugs as I wanted to do them anyway. Anything else worth doing whilst there? I ordered my new manifolds and Exhaust and already have my new turbo to fit so will do all at the same time. Are injectors easier to get to while engine is lowered? Thanks
Old Jan 25, 2018 | 01:07 PM
Mpsuk's Avatar
Also, can anyone clarify? When refilling coolant can you just run car and top up or is it necessary to pressurise the system? Lots of conflicting info online. Thanks
Old Jan 25, 2018 | 01:39 PM
s65e90's Avatar
s65e90 is infamous around these parts
If it's at a shop he may use a power bleeder for the coolant filling as it's easier, but it can be done by just lifting the rear and filling and topping off as the T-stat opens and leaving the bleeder valve up for a day or two.
While in there do the t-stat also and check the condition of the hoses right there. Nothing really else to do there as it's a simple relatively straight forward job.
Old Jan 25, 2018 | 02:04 PM
Mpsuk's Avatar
Not in a shop yet, may do it myself. Any idea how many hours it takes roughly? Thanks for the input
Old Jan 25, 2018 | 02:09 PM
s65e90's Avatar
I'd estimate 6 hours if your mechanically inclined. It's in there pretty good and requires some dismantling but not too bad. One bolt on the t-stat housing is annoying too in the back. There's a lot of good info on it. Here's a good DIY from user Slider.
https://www.6speedonline.com/forums/...ement-diy.html
Old Jan 25, 2018 | 02:16 PM
Mpsuk's Avatar
Thankyou
Old Jan 25, 2018 | 05:04 PM
Third-Reef's Avatar
Third-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond repute
When i did mine i wished i had a socket like this for the thermostat housing bolt in the back
Old May 18, 2018 | 11:11 AM
g8rdmd's Avatar
g8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to behold
Thumbs up
Thank you for this post, I ordered a set like this before I even started the job... Saved me a LOT of frustration!
Yves
Mar 27, 2014 05:03 AM
pureporsche
Sep 4, 2013 11:06 PM
FAST FWD
Aug 20, 2010 11:31 AM
OKHJOON190
Sep 30, 2004 11:02 AM
