2001 996 TT engine “Indicator Failure” with no start
Old Sep 21, 2019 | 06:59 AM
Midwest996TT's Avatar
Midwest996TT is infamous around these parts
Car was running fine May. Stores the car with battery trickle charger; but was **** off accidentally....by July. Car AGM battery dead. Recharged the battery. Got this dash warning and radio code missing. Thought it was related to radio and Immobilizer. Entered the radio code; all power equipment and keys work fine. Still warning engine Failure Indicator. See pic.
Switched batteries from H6 to 49
Scanned with icarsoft POR-II “can not connect”
Checked ECU/dash fuses and relays- all check good
Replaced the ignition switch
Scanned with Autel Maxicom- scanner skipped over DME module. I have pictures of results.
Ive been told that ECU in 996 will expire like this?
I don’t think ECU has a tune in it; .6-.7 boost.
Anything else like hidden relay or fuses other than foot well and relays behind passenger seat to check?
Dash light
Autel MaxiCom scan results
ECU in car
Old Sep 21, 2019 | 09:20 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
Markski is the go to guy for a broken computer on these cars.
Old Sep 21, 2019 | 09:39 AM
Thanks for heads up. How do I find him or company or website?
Old Sep 21, 2019 | 10:02 AM
brnrdtns's Avatar
markskituning.com He is located in Chicago.
Old Sep 21, 2019 | 04:41 PM
pancing's Avatar
pancing has a spectacular aura aboutpancing has a spectacular aura aboutpancing has a spectacular aura about
Before you do all thag check for mouse droppings and chewed through wires. No sense in gettinf an ecu just for it to fry again.
Old Sep 22, 2019 | 12:01 AM
Likely mouse nest areas on 996?
Yes, good point. I've not seen any evidence of rodents or smell anything either. I've checked by driver footwell, battery tray and back behind the just seats by ECU.
Any suggestions?
Old Sep 22, 2019 | 05:15 AM
Thanks, in contact.
Old Sep 22, 2019 | 08:44 AM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
for my understanding you charged your low batterie with connection to the car. That is not the best way.
Have you ever try to disconnect your battery now and connect it after a short time (reset ECU)
did you try the second key
vr6tee
Apr 25, 2016 04:59 PM
luckydanel
Feb 12, 2015 10:36 AM
996TTer
Jan 28, 2011 03:39 PM
archie2k
Nov 26, 2010 02:26 PM
smithk3933
Apr 11, 2010 04:50 PM
