Pss9 Noise?
Old Jan 13, 2007 | 07:02 PM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
Pss9 Noise?
Had Pss9's Installed With H&r Sways, When I Turn The Steering From Side To Side It Sounds Like Popping Noise, Anyone Have Any Ideas?
Old Jan 13, 2007 | 07:04 PM
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
Yes, it's probably your drop links. You'll probably only notice when you turn to full lock. Mine does the same thing. What links did you go with?
Old Jan 13, 2007 | 07:09 PM
The Drop Links That Came With The Pss9's
Old Jan 13, 2007 | 07:21 PM
wross996TT's Avatar
Are you talking a twanging kind of sound when you move the steering wheel to the extremes (at a stop or slow speed)? If so, the installer did not use the rubber washers off the stock suspension and they need to use them to stop the noise.
Old Jan 13, 2007 | 07:22 PM
i'm not a a turbo suspension expert. i had to buy aftermarket drop links to work with my GT3 sway bars.
does bilstein include drop links with just the coilovers? my pss9's did not include links.
the drop links are usually more of a sway bar fitment issue. i would think the pss9's would drop right in without changing the links.
anyway, like i said. it's your drop links binding at full lock with the sway bars. it's not a big deal. you'll also be glad to hear you'll probably be noticing some clunking and other random unpleasant noises after replacing all your suspension components
Old Jan 13, 2007 | 07:26 PM
iLLM3's Avatar
It's the droplinks, had the same thing! Im getting new droplink's for the new owner, because the noise at full lock is annoying
Old Jan 13, 2007 | 07:28 PM
Deputydog, Maybe The New Links Came With The H&r Bars, Not Real Sure,had The Pss9's & Bars Installed At The Same Time.
Old Jan 13, 2007 | 07:31 PM
Wross, Used The Stock Rubber Washers On The Rear But Not On The Front, The Coilovers Did Not Have Any Rubber Washers For The Front With The Kit.
Old Jan 13, 2007 | 07:32 PM
What Droplinks Need To Be Used To Avoid All The Klanking (professional Term).
Old Jan 13, 2007 | 07:47 PM
wross996TT's Avatar
You are supposed to use the stock ones in the front....that will remove the twang.
Old Jan 13, 2007 | 08:16 PM
Honestly, I don't think it matters. It's just a symptom of the adjustable aftermarket links. It only occurs at full lock. They get loaded up and pop when at full lock. Not much you can do about it that I know of. Besides, how often are you at full lock anyway?
Old Jan 14, 2007 | 08:03 AM
Its Not Only At Full Lock. Turning The Wheel In Any Direction It Makes A Twangy (wross's Term) Sound.
Old Jan 14, 2007 | 10:10 AM
wross996TT's Avatar
Old Jan 14, 2007 | 10:37 AM
Gunther's Avatar
Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !
I got rid of the sound by installing a roller bearing in the place of the plastic/rubber ones that came with the PSS9 set-up. Unfortunately I can not remember where I got them but it was posted here on 6speed.
Old Jan 14, 2007 | 12:26 PM
is it only while driving or will it make this noise when stopped and turning the wheel?
if it will do it while stopped, my guess is that they didn't unload the suspension while installing the sway bars. you may need to bring it back, have them unload the suspension, and loosen/adjust/retighten the drop links to the sway bars.
rob4wellness
Oct 2, 2015 07:32 AM
Ronny-
Sep 30, 2015 07:30 PM
Zero911
Sep 24, 2015 06:33 PM
