Official Turbo Weight Loss Thread/ Lightest Turbo List
Rating: Thread Rating: 4 votes, 4.75 average.
Old Jan 26, 2012 | 06:14 AM
  #751
jcars1990's Avatar
jcars1990 is infamous around these parts
great info on this thread
Old Feb 11, 2012 | 03:23 PM
  #752
besiktas's Avatar
besiktas is infamous around these partsbesiktas is infamous around these parts
does anybody know how heavy are the turbo doors?
i found a cf one which weights 3,3 kilograms (around 7 pounds) and I was wondering how much weight would I save by doing that.
Old Feb 11, 2012 | 08:02 PM
  #753
heavychevy's Avatar
I don't know exactly but I saved about 70 lbs switching to gutted stock doors so you would save more. I imagine 90-100.
Old Feb 11, 2012 | 08:05 PM
  #754
Blockhed's Avatar
Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !
thats some big weight savings
Old Feb 12, 2012 | 07:10 PM
  #755
besiktas's Avatar
70 lbs with removing the inside portion of the door?
I'm not looking to remove these parts, I was just curious about replacing the doors with CF ones (7 pounds) with remaining all the other inside parts. If it is around 20-30 pounds, that would be worth doing.
Old Feb 24, 2012 | 09:28 PM
  #756
randomquickness's Avatar
randomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to behold
well I'm getting my suspension done next week and I imagine I'll get a total weight when they do the alignment and corner balance. If not, I'll go get it weighed at the weigh station because I don't see myself doing any more mods for a while.
Old Feb 25, 2012 | 07:34 AM
  #757
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Randomquickness we'll be waiting for your final results and pics also,please.
Old Feb 26, 2012 | 12:43 PM
  #758
Blockhed's Avatar
Anyone got a weight on Volk Te37 18x8.5/11
  #759
Blockhed's Avatar
random, do you have a complete list of changes and deletes?
Old Feb 26, 2012 | 01:53 PM
  #760
ttboost's Avatar
Hey Adam...try this...
http://www.miata.net/faq/wheel_weights.html
Old Feb 26, 2012 | 02:28 PM
  #761
sure, check my purchase/build thread:
https://www.6speedonline.com/forums/...e-tonight.html
Old Mar 4, 2012 | 07:02 PM
  #762
Steve Theodore's Avatar
Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !
Hey guys,
I'm back with my digital scale to help dispell the final myths of how much the rear wing assembly weighs. As usual, things don't weigh as much as I've read or hoped they would, but I wanted to take the time to share real numbers with you guys.
First, the rear wing hardware (keep in mind I've already removed the hydraulic pump motor and lines, you can see those results earlier in this thread).
Here is the rear wing hardware for the under-decklid supports and the supports themselves, and finally the rear wing with the support rods too. The rear wing was exceptionally hard for me to weigh as I did need to support it, but assume that 7 pounds is about right.
So, for those keeping score, as much as I hate to say it, the entire rear wing assembly altogether is about 12.5 pounds (give or take). That's for the wing assembly, the assembly which holds it up, and the hydraulic pump motor, and all associated hardware.
Sorry for the bad news to everyone who thought that it was ultimately heavier, and offered interesting weight loss possibilities to go to a fixed mount kit. I was certainly one of those people, but had to see for myself!
*EDIT* I was semi-bothered about the wing measurement itself so I tried again on a less accurate scale as myself, then myself holding the rear wing (so at least it wasn't leaning on anything). It may weigh as much as 8 pounds as a result of that measurement. Still, I'd put the range of the entire rear assembly between 12.5 pounds and 13.5 pounds for every single required part. So, not even 15 pounds complete. The semi-good news is that you can really tell that the rear decklid feels lighter without all the wing mechanism installed, so at least there is something to look forward to there!
Old Mar 30, 2012 | 06:44 AM
  #763
Does anyone know much about the 'GT3' rear cross member? I was reading on another thread that it is aluminum compared to the standard 996TT steel rear cross member. Obviously, if that is true, sounds like a weight loss opportunity, but I'm unaware of the details involved. Can anyone debunk this? Thanks!
Old Mar 30, 2012 | 10:27 AM
  #764
heavychevy's Avatar
Steve, that's a good question, I would be interested in knowing this as well.
As for the wing, I posted some time back, can't remember if in this thread or not, that the rear wing on the Turbo is REALLY light. You'd need an ALL CF decklid and wing to save much weight. Once you see the lengths Porsche went though to keep the weight down, but still have a car built like a tank, it's pretty amazing.
Although I would have rather added a few lbs and had better attachments on the cooling system.
Old Apr 11, 2012 | 03:19 PM
  #765
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Dez,
I weighed my car recently after the Texas Mile. 1/4 tank of gas. 3240lbs
I could be well under 3140 with one seat, the bar, and harness removed and add a 5lb light weight battery.
With the following in place:
2 Rottec CGT seats (recline able 28lbs each)
1 Agency Power roll bar with cross brace (44lbs)
Status 5 point harness (8lbs)
1 Fire extinguisher
1 red top Optima battery (25lbs)
HRE 18" C20r wheels
Brembo GT-r Brakes and rotors
Straight Pipes (15lbs)
Front floor mats
With the following removed:
Stock seats
rear seats (belts in place still)
Spare tire and tools removed
Front drive and drive shaft
Rear Wiper
Rear wing motors
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
