A running pictorial of my monster Protomotive build
Old May 6, 2007 | 08:12 PM
  #286
Divexxtreme's Avatar
Originally Posted by geetee
I see. So your hitting full boost around 4500 vs. 5000 rpms with a GT35?
I'm not positive where full boost is with a GT35. Mark should be able to tell you.
Old May 6, 2007 | 08:13 PM
  #287
cjv's Avatar
cjv
Moderator
Originally Posted by Divexxtreme
Update:
My car just made 589 rwhp at it's lowest boost setting (.8 BAR/11.5 psi...boost controller turned off) at only 7,700 rpm. Should hit 600+ rwhp if/when we increase rpm. More numbers to follow as tuning progresses.
Scott.
Your motor makes 500 hp by 4500 rpm's. It stays between 500 and 525 hp between 4500 and 7000 rpm's. Actually it loses a tad between 5200 and 6200 rpm's. From there it picks up another 50+ hp from 7000 to 7700. What is Todd's explanation for this?
Old May 6, 2007 | 08:15 PM
  #288
Originally Posted by cjv
Scott.
Your motor makes 500 hp by 5000 rpm's. It stays between 500 and 525 hp between 5000 and 7000 rpm's. From there it icks up another 50+ hp from 7000 to 7700. What is Todd's explanation for this?
Tuning isn't complete yet, Chad. It actually just got started.
Old May 6, 2007 | 08:24 PM
  #289
cjv's Avatar
cjv
Moderator
I haven't been following your build. Do you know what size fuel lines (s & r) that the car is using? Anything with the pumps and injectors? Did Todd do anything with the cams? Not being critical. I'm trying to figure something out.
Old May 6, 2007 | 08:29 PM
  #290
Same fuel lines, pumps and injectors as Markski's car. Intake and exhaust cams have been hardwelded and reground. Ported/polished heads, stiffer valve springs, GT3 cam synchs and GT3 code on the 996TT ECU.
Old May 6, 2007 | 09:06 PM
  #291
cjv's Avatar
cjv
Moderator
By chance did Todd eliminate the vario cam and accuators handwelding and regrinding the upper lobes? Where by just utilizing the upper lobes only.
Your torque is coming on fast and strong which is excellent for .8 bar. What confuses me is once it hits it's peak it drops almost as fast which is hampering the hp. When it starts to recover the power jumps again. If Todd did what I suspect (above) then he is on uncharted ground above 5300 rpm's and further adjustments are going to be really interesting. Know how Todd does his homework you are probably in for a real treat.
My other thought is the 76 mm impellar may be too much after the torque max's out resulting in a temporary drag on the hp. Whatever, you are providing great info. Thanks and the best of luck.
Old May 6, 2007 | 09:11 PM
  #292
iLLM3's Avatar
Nothing really to say besides keep it coming fella's, soaking all of this info up. Scott almost done I see, getting excited??
Old May 6, 2007 | 11:18 PM
  #293
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
Congratulations Scott . . . those are great numbers. It is interesting to see how similar our HP curves are given the similarities in our turbos. Ill explain when we talk next.
1.7-1.8 bar is a lot of boost with the power you will be making. I am not going that high . . . want to keep the heads secure.
Craig
Old May 7, 2007 | 11:20 AM
  #294
WOODTSTER's Avatar
Nice numbers Scott,
Now turn up the Boost and let life begin!!!
MK
Old May 7, 2007 | 11:28 AM
  #295
topgun's Avatar
topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !
Scott, I'm glad your up & running! Congrats! Now lets get some drag numbers
Old May 7, 2007 | 11:39 AM
  #296
Thanks, guys. I'm really looking forward to completing mid and high boost tuning as well. More to follow.
Old May 7, 2007 | 02:19 PM
  #297
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
Scott,
When do think you will be finished with the tuning? And are you going to have time to fit in a track day before you leave again? I can't wait to see your new times...
Old May 7, 2007 | 03:00 PM
  #298
Originally Posted by John D II
Scott,
Not sure, John. I have a track day scheduled for this coming Friday, so I'm hoping the car is back by then. With my schedule, I have no idea when the next time I'll be able to attend a track day will be.
Old May 7, 2007 | 03:42 PM
  #299
John D's Avatar
I hope you're able to make it this Friday - that would be great!
Old May 7, 2007 | 05:54 PM
  #300
Craig
Thanks, Craig.
IRT to the boost levels, we're playing it by ear. However; the heads are O-ringed and the bottom-end is built, so I don't foresee any problems.
