Dectane/Depo lights?
Old Apr 29, 2014 | 02:39 AM
  #166
yah996's Avatar
yah996 is infamous around these partsyah996 is infamous around these parts
Originally Posted by artyve
For the electrical engineers (and those more electrically inclined), a couple of questions.
1) It looks like most of the people here encounter this problem approximately a year or so after installing the DEPO lights. Why did the lights work properly for a year before failing?
2) Why does this DIY fix use two 6ohm resisters in serial instead of one 12ohm resistor by itself?
Thanks!
Pin 1 to 2 (brake light): 0.6 Ohms
Pin 3 to 2 (reverse light): 0.6 Ohms
Pin 5 to 2 (fog light): 0.6 Ohms
Pin 4 to 2 (turn signal): 0.6 Ohms
Pin 6 to 2 (tail lights): 1.0 Ohms
This measurements are totally incorrect, sorry. This are the values in cold conditions. You should measure the current during operation!
Serial : 6ohm + 6ohm = 12ohm
Parallel would be : 6ohm / 6ohm = 3ohm - This will burn up the gateway...
Calculations for the correct resistor:
Normal battery and 10 ohm!
14.4 Volt / 10 ohm = 1.44 Amp --> 14.4 Volt * 1.44 Amp ~ 20,7 Watt
On weak battery and 12 ohm...
12.5 Volt / 12 ohm = 1.04 Amp --> 12.5 Volt * 1.04 Amp ~ 13.02 Watt
up 10% tolerance on the resistors can be normal
The leds will consume not more the 2~3 Watts
Old Apr 29, 2014 | 04:30 AM
  #167
michelin's Avatar
michelin is infamous around these parts
Well, my dashboard now has a 'check rear tail light' warning!
It came up this morning and coupled with it my number plate lamps occassionally do not illuminate.
Any help appreciated.
Old May 13, 2014 | 06:44 AM
  #168
Crossfire190's Avatar
Crossfire190 is infamous around these parts
I was having the same problem. "Left Tail Light Out". I had the Depo lights for over a year with no prior issues. I just installed "The Fix" on the left tail light. Everything is working great now.
I do have one question. The resistors do get very hot. Any concerns with melting the wires? Has anyone who has done this checked to see if there are any issues with the heat?
Old May 13, 2014 | 07:32 AM
  #169
Squat's Avatar
Squat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to behold
I have it here and there i just unplug plug them and walla. All is well
Old May 13, 2014 | 10:49 AM
  #170
jjurroz's Avatar
jjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant future
where is the cheapest place to get the dectane/depo tail lights?
Old May 13, 2014 | 11:54 AM
  #171
jhbrennan's Avatar
Better off asking who provides best guarantee and customer service - I'd suggest FVD or Carlightpros.
Old May 13, 2014 | 01:28 PM
  #172
1pennyshort's Avatar
1pennyshort has a spectacular aura about1pennyshort has a spectacular aura about1pennyshort has a spectacular aura about
I was concerned with the heat as well, but everything's been holding up fine for several months now. I did double-tape the resistors to the metal body, to help dissipate the heat a bit, but I can't tell if it helped or not. There is a lot of heat coming from the engine compartment too.
Old Jun 28, 2014 | 01:31 AM
  #173
coquitlam1's Avatar
coquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of light
does anyone know that depo (factory) might have improved LED tail light, so we don't have to do all these works? thank you.
Old Jun 28, 2014 | 01:45 AM
  #174
jhbrennan's Avatar
Installed my DEPO 3 years ago - used resistor packs that came with lights - no other "works" needed. Have worked flawlessly.
Old Jun 30, 2014 | 07:42 AM
  #175
Adam997's Avatar
Adam997 is infamous around these parts
hmmm interesting problem... i want to take one of these
Old Jul 31, 2014 | 01:52 AM
  #176
coquitlam1's Avatar
just got a brand new set of Depo light. Each light comes with 2 resisters sealed in a black box attached to light housing. Seller claimed this is a newly improved version. But I don't know if this is same as older one.
I have installed it and they seem fine. But I have not driven the car yet.......
Old Jul 31, 2014 | 02:59 AM
  #177
born2boost's Avatar
born2boost is infamous around these parts
Hi Guys
I am quite keen to get a set of these LED Lights...What can you recommend? Which ones should I get and from where??
Please advise
Thanks!
Old Jul 31, 2014 | 07:18 AM
  #178
pureporsche's Avatar
pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !
Hey guy's I'm selling mine (Dectane) as I'm upgrading the entire bumper to a 997.2
Haven't posted in the salesection, but will shortly.
They are clear with a slight smoke, all LED's work, in excellent condition, and most importantly they don't throw any errors.
Let me know if you are interested - $500 Canadian + shipping (shipped from Vancouver)
PM me if you are interested and want to get a head start.
EDIT: Listed for sale here
Old Jul 31, 2014 | 01:12 PM
  #179
coquitlam1's Avatar
dam, if you listed for sale 1 week earlier, then I didn't have to buy a new one.....
Old Jul 31, 2014 | 01:51 PM
  #180
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
i am fairly sure that smoke lens are not DOT approved and thus i think will void your insurance warranty. At least i think that is how it works. If instance, if someone rear ended you, It can be said that you had aftermarket non- DOT approved lights and thus contributed to the accident.
