Dectane/Depo lights?
Hey guys. I a, not an electronics expert but I think as along as you get the right ohm rating it won't matter what type. That said I would believe the square box type would be much easier to mount and dissipate heat more effectively
DC
I personally purchase the LED light from the factory in Taiwan for my 997. The Light is malfunction, same as all of the folks, the situation appear after 4 months from purchasing, Taiwan said they dont have any stock and no replacement at all, I am very disappointed about it. and this warning keeps warn me everyday. annoying
I have a set of the Dectane Taillights that I am selling if anyone is interested in swapping to LED. The resistor fix is as outlined in thread #199
$300- you cover shipping. / Sold
Kelly
Kelly
I've spent an hour looking, but now that I've failed, I thought I'd reach out here:
I remember once running across a thread where someone had opened up and modified/improved the DEPO lights to have a full-surround brake light - i.e., not the inverted "C" shape they typically have when braking. Does anyone still have a link to that thread or otherwise have any of you tried it? I'm considering buying a set of the DEPOs (probably with the smoked center section) and would much prefer if they (a) only had an outer "C" lit during normal running operation and (b) had the full surround lit when braking. I'm sure there's a way to do it with some work but would like to see where someone else has done it in the past.
Update: Looks like I didn't quite look long enough. I finally found the thread here. It looks like there was never a final post indicating exactly how it was done. Disappointing.
Who needs a wife when you have a Porsche? Generally I'd agree (re: not seeing the back often) but it would still bother me. I'd actually even be interested in reaching out to DEPO themselves directly to try to make some changes to improve these so that we don't need to do anything to them. Does anyone here have any contacts with them?
Hi guys, I'm a new 997 owner (first post!) and as you guessed, looking to replace the stock tails. I know I'm resurrecting an old thread but I'm wondering...It's been over 4 years since G-Force posted his amazing fix. Are your taillights still working? How many members had to implement this fix?
I can confirm that I tried this fix and it worked for one of my taillights which was going off and I did it immediately for the other tail light too. Very happy and many thanks to G-ForceTarga4S
but yeah
doable very easily once u know the wirings
