Dectane/Depo lights?
Old Jul 31, 2014 | 06:55 PM
  #181
pureporsche's Avatar
pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !
Originally Posted by Jako
i am fairly sure that smoke lens are not DOT approved and thus i think will void your insurance warranty. At least i think that is how it works. If instance, if someone rear ended you, It can be said that you had aftermarket non- DOT approved lights and thus contributed to the accident.
Nope, they are not blacked out. Not aftermarket either - came from the factory that way.
They are lightly smoked - been in front of many a cop and have a cop friend, never an issue.
Old Aug 10, 2014 | 11:19 PM
  #182
DNugget991GT3's Avatar
im having the same problem as the OP now. right tail light randomly turns off. It works again when i cycle the lights on and off.
im going to try to get a replacement resistor and hope that solves my problem.
Old Aug 11, 2014 | 12:11 AM
  #183
coquitlam1's Avatar
coquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of light
I have installed the new Depo light and driven several time (also in the night for about 20 mins). So far, all is fine.
Old Aug 11, 2014 | 04:54 AM
  #184
PACE's Avatar
PACE has much to be proud ofPACE has much to be proud ofPACE has much to be proud ofPACE has much to be proud ofPACE has much to be proud ofPACE has much to be proud ofPACE has much to be proud ofPACE has much to be proud ofPACE has much to be proud of
The resistors do the trick 100%. I have some extra if anyone needs them. Half off retail. Let me know.
Old Aug 11, 2014 | 08:24 AM
  #185
artyve's Avatar
artyve is infamous around these parts
Just want to add my results. Over the weekend, I added the resistors based on G-forceTarga4S post on page 6 of this thread (thanks G-forceTarga4S!). So far, the resistors are working properly and I am no longer getting any error codes. The resistors do get quite hot, so I recommend attaching them to a body panel. For me, I used 3M Automotive Acrylic Plus double sided tape to mount the resistors to the back of the tail light cavity as per this thread I found online:
http://www.lxforums.com/board/showth...r-Installation
I'll be checking on them in a month's time to ensure that the tape is able to withstand the heat of the resistors.
Old Aug 11, 2014 | 08:42 AM
  #186
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
Have people provided feedback to the manufacturer? It baffles me that customers need to go through all of this just to enjoy this product. Dectane should have the proper step down circuit built into their product. Would be such an easy fix right from the factory.
Old Aug 11, 2014 | 09:47 AM
  #187
jhbrennan's Avatar
Not sure how you get this feedback to a manufacturer in Taiwan - maybe through the distributors?
Old Aug 11, 2014 | 11:11 AM
  #188
coquitlam1's Avatar
I was told by distributor that the DEPO has improved their products at this year (2014). That is why I bought a new set from a new batch (I was told the new batch should be a trouble free product.... and I hope so)
Old Aug 11, 2014 | 11:18 AM
  #189
Squat's Avatar
Squat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to behold
Thats the thing some of us have had success others its a misery index of 10. The problem is getting the LEDs right. I wonder if they didnt have so much going on if it would be fine. IE they have some LEDS lit up sometimes and not others. For instant make it a full D look instead of the C.
Old Aug 12, 2014 | 03:02 PM
  #190
CHeck your PM, Pace.
Old Aug 12, 2014 | 10:48 PM
  #191
Jako's Avatar
Hi Coquitlam, which distributor did you use? I would be curious how to ensure, if i ordered a set, i would be recieving the improved version.
Old Aug 13, 2014 | 01:05 AM
  #192
coquitlam1's Avatar
hi, Jako, I use Ellie at fish123 and she is pretty nice and fast response. She confirmed I will receive the new batch. The set I received have 2 resistor boxes attached on each light and they are already wired into the light. I thought that the older one come with 1 resistor and 1 additional resistors and you can choose to use the additional one or not. To be honest, I don't know whether mine is new batch or not, but it seems different than the older one. So far, I have no issue and I am happy with it. Good luck
Old Aug 13, 2014 | 06:17 AM
  #193
jhbrennan's Avatar
The "older ones" I received (4 years ago) came with two resistor boxes that were plugged in line to the wiring harness. I never had any problems with these lights. Bought from CarLightPro. Watch the install video on the CarLightPro site and you can see the resistor boxes during the install.
Old Aug 21, 2014 | 11:41 AM
  #194
coquitlam1's Avatar
the 2 resister boxes on my LED light were actually all bolted on the housing which is different then from the one in CarLightPro video.
Old Aug 21, 2014 | 11:56 AM
  #195
not having any luck finding resistors.
member Pace says he has spare resistors laying around but hasnt been online in a week. anyone have a way of getting in contact with him? or can anyone tell me where to get the resistors ?
