997TT MK.1 PCM 3 conversion DONE :)
Old Mar 9, 2017 | 05:04 PM
  #541
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
Originally Posted by cakM3
Thanks DC for posting the wiring diagrams!
No worries...Happy to help.
DC
Old May 22, 2017 | 08:40 AM
  #542
coquitlam1's Avatar
coquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of light
Hi, there,
As I don't really know how to repining to create proper and correct connectors, even with these diagrams. . But I do appreciate DC help and also help from Serg124, PAULG........ Can anyone produce the connector for below:
1. between PCM 3.0 and old current wire connector.
2. between new AMP and old current wire connector.
Thank you very much.
Old May 22, 2017 | 09:13 AM
  #543
Originally Posted by coquitlam1
Hi, there,
item 1 can be made for item 2 you have to depin the whole plug and repin.
#TeamAIM
Old May 22, 2017 | 06:01 PM
  #544
coquitlam1's Avatar
I think I saw Monster1 posted a convert for item 2 at #323, page 22. That is really cool, if someone can make these custom converters by providing our car model year and option .....
Old Jun 20, 2017 | 11:56 PM
  #545
997tt_'s Avatar
997tt_ is infamous around these parts
Hello Guys,
a friend with a bose turbo would also like to have the pcm3 instead of the 2.1.
Is the only bose amp that works 99764544404?
As this one is very hard to find used at a reasonable price.
Old Jul 27, 2017 | 02:42 PM
  #546
JJT's Avatar
JJT
JJT is infamous around these parts
I am looking for the codes for the update.
Old Jul 28, 2017 | 03:21 PM
  #547
Serg124's Avatar
Serg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond repute
Old Jul 28, 2017 | 03:32 PM
  #548
JJT's Avatar
JJT
Originally Posted by Serg124
Received and working.
Old Jul 28, 2017 | 11:48 PM
  #549
997tt_'s Avatar
What codes and what update have you done?
Old Aug 29, 2017 | 02:34 PM
  #550
911turbocabrio997's Avatar
911turbocabrio997 is infamous around these parts
Hello Guys,
i want to do the conversion and repinned the connectors behind the pcm3 and all pins at the new bose amp except the three from the small socket.
Is it correct that the 09 bose amp has no pins in this socket?
Where can i buy the pins that fit the big black socket with 32pins?
From the wire plan i can see that
B1 VNC+ goes to A27 at the new amp
B10 VNC- goes ti A26 at the new amp
B5 Wake Up goes to A29 at the new amp
All other cables i have repinned, but the 3 from the small socket wont fit to the big connector
I will cut them and solder new pins on it, but i do not know the number to order them at the dealership?
It would be great if someone can help so that i can test if it works.
The car is a 997 Turbo Cabriolet from 2008
Old Sep 10, 2017 | 01:44 PM
  #551
Serg124's Avatar
yea, there can be such a problem. actually you can order them at mercedes benz dealer.
a0035407881 - big plug
a0185458626 - smaller size pins
a0135457826 - middle size pins
a0185454726 - bigger size pins
Old Sep 24, 2017 | 01:26 AM
  #552
thanks serg
I rewired the amp and connected the big old plug to new amp 7pp.035.223.p.
When i lock it the violet insert comes out a little.
But the bigger problem is that the pcm3 does not start at all
I checked the fuses and the 10amp fuse was broken as the old pcm2,1 also didnt worked.
I replaced the fuse and tried the pcm 3 but nothing happened when i plugged it in.
When i tried the pcm 2,1 it started but didnt had the amp nvi and so on as i didnt connect the modt bus.
Do you have an idea what the problem could be?
Old Sep 24, 2017 | 02:42 AM
  #553
Serg124's Avatar
Did you check your pcm3 earlier? Did you saw it working?
Old Jan 15, 2018 | 03:45 AM
  #554
Stroker's Avatar
Stroker is infamous around these parts
Codes are still available?
Old Jan 15, 2018 | 03:49 AM
  #555
Serg124's Avatar
Sure
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
