WOW! ROTtec 997.1 DRL LED's
Old Feb 11, 2012 | 04:10 PM
  #271
synergy's Avatar
synergy is a splendid one to beholdsynergy is a splendid one to beholdsynergy is a splendid one to beholdsynergy is a splendid one to beholdsynergy is a splendid one to beholdsynergy is a splendid one to beholdsynergy is a splendid one to behold
Originally Posted by Doug_B_928
Porsche convention is that left is the driver's side and right is the passenger side.
Ok thanks for clarifying....that is what I thought
Old Feb 11, 2012 | 04:13 PM
  #272
Justin Kresty's Avatar
Justin Kresty is infamous around these parts
I really like the way these look on the black 997s.
Justin Kresty
Old Feb 15, 2012 | 06:27 PM
  #273
krerra S's Avatar
krerra S is infamous around these parts
Synergy, just wanted to follow up on the front module, that was problem, fault had nothing to do with lights. Thanks again very much.
Old Dec 3, 2012 | 10:50 PM
  #274
Musclehedz101's Avatar
Musclehedz101 has much to be proud ofMusclehedz101 has much to be proud ofMusclehedz101 has much to be proud ofMusclehedz101 has much to be proud ofMusclehedz101 has much to be proud ofMusclehedz101 has much to be proud ofMusclehedz101 has much to be proud ofMusclehedz101 has much to be proud ofMusclehedz101 has much to be proud ofMusclehedz101 has much to be proud of
Originally Posted by TT2911
Yes, I figured out the original install process when I installed the Dectane DRL module in my 2006. You simply cut the dectane connector off each pair of DRL wires, add 2' of wire so they are long enough to reach to the area of the lights themselves, then you T tap the positive wire to the porsche positive wire (I forget the color) and the ground to the porsche brown wire for the foglight wires. The foglights are the most inboard of the sockets. You also hook 1 orange wire to the porsche positive wire (red/white I think) on the park light. This wire senses when you turn on the park or headlights and shuts the DRL's off.
The red and black wires go to the psoitive and negative terminals of the battery. The module simply senses the current flow when you turn the key on and detects the current flow has stopped when you shut the key off. I can tell you the DRL's come on as soon as you turn the key on, and they stay on for 5 seconds after the key has been shut off. If that aspect of the module concerns you, buy the TFML01 unit. It does exactly the same thing as the 03 unit but instead of automatically sensing the "key on" via voltage, it uses a wire that you have to hook to your fuse box to a key switched circuit. You'll have to fish that wire through the firewall and down to your fuse box unless you can find a switched circuit under the hood. I opted to go with the automatic unit because it was 1 less wire to fiddle with and it seems to work fine.
I just wanted to verify but in your current configuration you have the Dectane DRl module connected to the positive & negative Parking Lights (center light bar on LED DRL'S) OR Fog Lights?
Old Dec 4, 2012 | 07:54 AM
  #275
TT2911's Avatar
TT2911 is just really niceTT2911 is just really niceTT2911 is just really niceTT2911 is just really niceTT2911 is just really nice
The DRL module controls the fog lights when the park or headlights are not turned on. That way you have the white LED's on as daytime running lights. When you turn on the park/headlights, the module senses it and turns the DRL's off. Everything, including the fog lights, then work as normal.
Old Dec 4, 2012 | 01:12 PM
  #276
CayenneS2083's Avatar
CayenneS2083 is just really niceCayenneS2083 is just really niceCayenneS2083 is just really niceCayenneS2083 is just really niceCayenneS2083 is just really nice
I'm buying the front LEDs but am thinking of wiring them a bit differently. Basically, I want to connect the car's parking light to led row and the car's fog light to the then bar. Basically I want to do this because I hate that the leds and the bar are on at the same time.
WOuld the voltage work if I connected the cars fog to the led bar or would that damage something?
Old Dec 4, 2012 | 03:38 PM
  #277
TT2911's Avatar
All the voltages are the same, I dont think you would hurt anything. Only problem you might have is if the led's have different amperage draw and your computer thinks you have a burned out bulb as a result. You would get an error message in that case.
Old Dec 9, 2012 | 11:17 PM
  #278
coolcat's Avatar
coolcat is infamous around these parts
Does anyone have a video for the actual removal of DRL's?
Old Dec 21, 2012 | 08:12 AM
  #279
So I decided to wire up my lights a little diferently because I hate having the lower and middle leds on at the same time. Basically, I'm wiring in a relay that shuts the power to the parking lights (led bar) whenever the fogs (lower leds) are on. Combined with the utkinpol hack this will give me the lower leds as drls, the middle strip when i turn on the lights, and then only the lower less whenever I turn on the fogs. I'll put up some pics when and if I get it to work.
BTW i found the connector that porsche uses for the parking lights. BMW uses the same one and you can buy it at any dealer. Its useful if some one needs to hook up a resistor, etc and doesn't want to splice into the factory wires.
http://haferman.org/bmw/
Old Dec 24, 2012 | 11:57 AM
  #280
Ynot's Avatar
Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !
I ended up taking the whole front bumper off, I tried putting the credit card to get it out w/o success. Even with the front bumper off, I ended up breaking the plastic clip that holds on to the front bumper. I had to get a drummel tool and cut it off. Mine was extremely difficult and there is no way that the credit card method would work. It all worked out b/c I wanted to installed the front bumper grill. I just ordered it last week and waiting for it so I can install it.
Old Jan 25, 2013 | 01:55 PM
  #281
Just curious to see how this turned out for you?
Old Jan 26, 2013 | 07:37 AM
  #282
CHAOS236's Avatar
CHAOS236 is infamous around these partsCHAOS236 is infamous around these parts
Very nice.
NRoy7
Jul 4, 2022 04:03 AM
3WDistributing
Jun 16, 2016 12:34 PM
XLR82XS
Oct 5, 2015 07:02 AM
NRoy7
Sep 19, 2015 06:59 AM
nick-seattle
Sep 18, 2015 08:14 AM
