Greetings from Niagara, Ontario, Canada
Im going to do the light smoke front markers and side repeaters . With the car being red Im going to leave the rears alone .
Now If I could just get Rich to answer my question on when they will have stock on front markers it will all be good .
With two different colours it looked odd, so I just went with white instead for the side repeaters.
I agree! Now it shocks AMOC members on how many miles I have on my "beater" when it's looking so good parked next a bunch of very low mileage examples
Less than a 1/2 mile away and super secure facility, so I'm happy with my temporary solution.
P.S. Mandatory garage for our next home and none with less than a 2 car garage is even being considered
Visiting family in Buckhorn, Ontario.
Cottage country 3 hours from Niagara in the Kawartha Lakes region.
Also stopped in Bobcaygeon for Fish 'n Chips and a little shopping.
Took a few more shots while it was relatively clean:
I even enjoyed trying some local craft beers:
Rich is active on the forum again so I'm sure he'll post when stock is available...
Driving home from the trip on the freeway, I did get an emissions warning and temporary CEL. I had known the front O2 sensor need changing before the upcoming emission test, but this was a new issue.
My hint was looking at the temperature guage and it was reading cool, not at it's normal 9 o'clock position.
When I got home scanning the ECM confirmed it - Low coolant temp DTC.
Luckily, I had been proactive and bought a new thermostat last year knowing it was a case of "when" not "if" it would need to be changed.
I watched Redpants video on the job and honestly it made it seem more difficult than it really is. I did appreciate knowing the size of the fasteners etc and other good tips in the video. Once opening the hood, it's a simple case of disconnect and move stuff that's in your way so you can remove the T-Stat cover. I did see why some people trim the stud for additional ease but it's not necessary as only the non-threaded part makes contact with the head. Job took less than 45 minutes and it fixed the issue
If you have any questions or comments, feel free to post them below...
Since I don't have a lift, I went to my local muffler shop that I have a good relationship with after many years of project cars.
I felt bad that the exhaust was warm so we had to wait a while for it to cool down. Price was right at $50 since I was supplying the sensors.
This was a good opportunity to take some better pictures of the underside of the Vantage...
FYI the green plugs are for the front pair and the blue plugs are the rear pair of O2 sensors.
After clearing the codes and driving it for a couple days, it's ready to go for the emissions test (so I can get my plate renewal sticker)
Hey Ryan, I'm sure you noticed while replacing the t-stat that the reason you were getting low temps is the rubber lip on the flange had come off and was jamming the t-stat open. This was an issue with this design t-stat that used small nibs to hold the rubber on the flange lip. It was subsequently removed from Ford use and replaced. (Ford had a huge issue with a line of truck engines using this t-stat due to the disintegration of the rubber flange.) As you see from your own pics the rubber can come off completely and get jammed in coolant passages causing further issues. It also breaks up into pieces meaning you have even less chance of getting smaller pieces out intact and they can cause significant damage if they jam block coolant passages.
Does the t-stat you installed have the same rubber seal or is it a single piece molded flange? There are at least two threads on here that detail the new improved Ford T-stat designed to prevent this potential.
Thread One
Thread Two - scroll down on this one to see the mangled broken rubber seal - looks like part of it may already be somewhere in the engine.
Thread One
Thanks for those links to other threads
Yes I caught mine so fast that it was still in one piece and all accounted for.
Assuming others have had a good experience with the Ford RT1163 T-Stat, I wouldn't hesitate to try one next time with an Aston housing o-ring seal.
Of course I'm a fan of improved design parts for known issues.
Not sure how long the Redpants Jag T-STAT will last but some members might chime in on how long or far they've lasted to date...
Went for the test after driving for a couple days with no warnings or trouble codes.
Good news is the test passed once I coached the tech on plugging into the correct port under the dash (the left one).
I also took a video to see the steps their test goes through for Ontario's Drive Clean test.
Got my new plate sticker and went from the the best colour combo to one of the worst - at least we don't have to put stickers on the windshield here...
