Greetings from Niagara, Ontario, Canada
Rating: Thread Rating: 4 votes, 5.00 average.
Old Apr 15, 2018 | 05:17 PM
  #391
007V8Vantage's Avatar
007V8Vantage is a glorious beacon of light007V8Vantage is a glorious beacon of light007V8Vantage is a glorious beacon of light007V8Vantage is a glorious beacon of light007V8Vantage is a glorious beacon of light
Post This afternoons project was building the side marker LED's...
First I tested to ensure all the 9 LED strip lights were working.
Next I used the AM part number on the smoked lens to make sure the red lights go in the rear markers and the amber in the front pair.
In order to get the lights in the sealed units, I drilled one 3/8" access hole per unit at one end. For the rears, The lights were fed in the hole and the male plug routed out the factory socket connector. For the fronts, the lights were fed in via the factory hole and the hole I made was for access for a pick tool. The pick is a 90 degree tool that served three purposes:
1) To arrange the strip LED's at the correct position
2) To ensure the power and ground wires were positioned alongside the strip lights
3) To pull and apply downward pressure on the light strips to adhere them to the backing plates with the supplied 3M tape
After the lights were in position and the plugs were accessible out the factory hole, I covered the access holes with electrical tape. You could also use a black silicone or adhesive. I went with the tape for now in case I need to re-position anything during the installation into the fenders and rear bumper.
Here are the pictures - I did the red rears first and second, then the amber fronts third and fourth.
Let me know if you have any questions:
First one done, the second takes half the time
Time for the fronts - a little more difficult feeding the lights the stock hole but I just took my time and it went fine. They are very flexible and the 3M tape doesn't stick until pressure is applied:
3 done and 1 to go:
I'm happy with the results, your results may vary
Top tip is to be very careful drilling to ensure you don't touch the lense when going through.
Also if you are wondering, I first tried to separate the units with heat but the plastic backing plate was getting soft before the glue let go - therefore above was the infamous "Plan B"
Old Apr 16, 2018 | 02:21 PM
  #392
MRCW's Avatar
Plan B looks good... how do they look lit up? Did you use amber and red LEDs or white to let the lens provide the color?
Old Apr 16, 2018 | 03:19 PM
  #393
Thumbs up Ask and you shall receive...
Yes you need to use coloured LEDs with the smoked lens.
I quickly touched the plugs to a 9 volt battery to give you an idea of the look.
On my smartphone the ambers look more like a yellow/green, but you get the idea:
Old Apr 19, 2018 | 05:42 PM
  #394
Cool Canpar delivery driver brightened my day...
upload images free
imag
Old Apr 19, 2018 | 05:45 PM
  #395
sonies's Avatar
5 Year Member
sonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud of
jealous, wish I had the funds right now for something like that! well that and some cats, and a tune, and a titanium exhaust, and some wilwood brakes, and a dbs shift **** and... lol $$$$
  #396
Old Apr 19, 2018 | 05:46 PM
  #397
handyman2009's Avatar
Veteran: Canadian Forces
Wow going all out their Ryan, that will definitely get the best out of your V8
Old Apr 19, 2018 | 05:48 PM
  #398
Aldv's Avatar
Aldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud of
Hopefully you saved some money to feed the cute dog...looks concerned! Lol
Very nice...
Old Apr 19, 2018 | 05:56 PM
  #399
Lightbulb
LOL, tell me about it.
In my mind I justified these because I need to replace my starter (which involves removing the right side exhaust manifold)
Old Apr 19, 2018 | 06:08 PM
  #400
Post
Yeah, looking forward to it.
Next I'm going to get the headers ceramic coated.
I visited a couple tuners to select a chassis dyno for RWHP testing.
However my issue is the Vantage won't crank over, so I might have to forgo the baseline testing and just measure after the mods are complete.
Old Apr 19, 2018 | 06:11 PM
  #401
sonies's Avatar
5 Year Member
perfect excuse! love it
Old Apr 19, 2018 | 06:14 PM
  #402
Very nice...
Thanks!
Luckily, I purposely bought the second cheapest Vantage I could find last year so that I would have some money available for "Performance Improvements".
Yes our dog "Aston" brightens every other day for me when I get home from work
My wife buys the dog food and I'm pretty sure it's one of the most expensive kinds available
Old Apr 19, 2018 | 07:00 PM
  #403
silver997's Avatar
silver997 is infamous around these parts
You gonna replace those headers yourself? I did mine over the winter. It's ummm.......Very time consuming and painful. Got small hands?
Old Apr 19, 2018 | 07:37 PM
  #404
My plan is to do the swap using my mechanic Scott's hoist and greater breadth of tools, plus his help. His hands are bigger than mine so he'll likely supervise during the bundle of snakes install.
Any further tips or suggestions from your experience would be appreciated....
Old Apr 19, 2018 | 10:01 PM
  #405
silver997's Avatar
If you have access to a lift. That should help. I did mine on jackstands, mind you I had the car 36" off the ground. The passenger side header is easier than the drivers side. So take off both front wheel wells, the front underbelly tray, and the plastic spark plug valve cover things. I would recommend spraying the bolts on the header at the block with some sort of penetrating fluid. That kinda sucks because it just ends up spraying back in your face due to no access. The bolts are robust, but you don't wanna strip them. Or break them. If you brake one of those bolts you might need to remove the engine to replace them. Be careful. Your probably gonna need to replace a couple of nuts after you take them off. I reused most of mine. Only use the factory nuts. They are designed to expand and contract under the heat. You need to release the motor mounts and move the engine up and down to access each bolt at the right angle. Go from the side or underneath to access each bolt. A mid rise socket, wobbly extension, u joint sockets and stubby wrench. Those help. The ERG pipe on the drivers side is really a pain to unbolt at the header. After you unbolt the header on the drivers side you have to move that corrugated heat shield on the car out of the way. There is also a main power cable behind the heat shield you need to move. The drivers side header will wiggle out but it's a tight fit, because there is a heat shield built into the stock header. If you have help it shouldn't be too bad. Hope this helps!
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
