Greetings from Niagara, Ontario, Canada
Most of the failed thermostats I've seen were 7-8 years old. The easiest way to manage the thermostat issue is to just replace it at the same time as your coolant, so every 5 years. Cheap insurance, I think. The biggest hassle with the thermostat change is managing the coolant that comes out of it, so the thermostat is easy when you're draining the coolant anyway.
So the fluid only lasts a day or two before the low washer fluid displays upon startup.
I decided to remove it from the car so out comes the wheel well liner yet again. Just a couple Torx bolts, 3 plugs, and 3 hoses to disconnect.
To my surprise the tank was not cracked or leaking so it is likely one of the seals.
I put vacuum caps on the pumps (one for windshield and other for headlights) and neither of them leaked a drop over 2 days.
The leak came from the back where the sensor is.
The seal has a flat side on it to clear the shape of the bottle - it was off by 90 degrees causing the leak. A lucky easy fix with no parts needed. I trimmed the hoses back a 1/2" for a new seal on the pumps as preventative maintenance.
Cleaned tank, reassembled, installed, primed and tested.
All good now as level hasn't dropped = success
I suggest connecting the fill hose first:
Lot of pics in sequential order may help someone out in the future
Hi Guys, wanted to share some pics from the day.
A record 22 Aston's participated in the spirited drive from Toronto to Kleinburg, Ontario for lunch at XXI Chophouse in the "Doctor's House".
An expert from B&O was on hand to educate on the sound system for the Aston Martin and a local tailor specializing in bespoke suits.
The unveiling was a Q 1of1 Silver Birch DB11 V8 (the DB5 Goldfinger colour) reported to have a 300 man hour paint job.
Happily, the speed limit appeared to be only a suggestion on the drive through rural winding country roads. What looked like rain in the early morning turned into a great weather day for a cruise. My black Vantage was easy to spot as the first with smoked marker lights
Header starter and cats installed
Took 4 hours a side over two days.
Most stud nuts accessed from side with liners removed.
Rest from underneath, top wasn't necessary.
Cats are easy except tightening top bolts are a little tight.
EGR plug added with tube removed.
New starter works great and no leaks from new gaskets.
I'll post some videos soon of the new sound.
Cost me $670 CDN.
Check out the pics and let me know if you have any questions.
Cost me $670 CDN.
Agreed!
If you've done the tune I'd appreciate any tips and/or a copy of the missing instructions....
First I checked and lubricated the valves:
With the fuse in the pump was running repeatedly telling me there is a leak in the vacuum system:
The culprit was a split vacuum line that connects the valve to a tee fitting. It was only 1-1/2" long so I grabbed some spare hose I had and another free fix for me:
To test my repair I use a piece of 2x4 and the power seat button to set rpm to just below and just over 1500 rpm. Now it's working like a charm
First thing I did was re-install the security package tray in the trunk
Driving around with the windows down is intoxicating and my average fuel consumption has increase the past week due to a more aggresive driving style
Initial startup to check new starter:
Driving with smartphone on the passenger seat and windows down:
Driving with Fuse 22 out:
Enjoy!
Enjoy!
https://www.youtube.com/watch?v=bVfjQp6gNPA
https://www.youtube.com/watch?v=LCocOuHTgmg
https://www.youtube.com/watch?v=wG4uS4N_d8E
Enjoy!
Enjoy!
Everything downstream of the 200 cell cats are OEM stock exhaust and muffler.
. Will try to capture a video! Did you do the Velocity AP clutch/flywheel when you did the headers?
