Biggest rubber on std 19”
Old Jun 10, 2021 | 02:50 PM
captain Greg's Avatar
captain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to behold
Please can someone advise me on the biggest tire I can fit on the OEM 19 inch rear rim? Currently I’m running 285 and I would like to go a bit wider if possible without compromising safe handling
Old Jun 10, 2021 | 10:23 PM
V12Stealth's Avatar
5 Year Member
V12Stealth
It would help if you said what car you have and which rims you're on. Physical tire sizes are also different from brand to brand. So e.g. 295 might be fine from one brand but not from another.
Old Jun 11, 2021 | 12:32 AM
Sorry my bad I have the OEM 19 inch wheels as per my pic
Old Jun 11, 2021 | 06:12 AM
embdenb's Avatar
I think 305 ( used on the v12 Vantage I believe) will fit. You might have to change the fender inner liner.
Old Jun 11, 2021 | 08:15 AM
61mga's Avatar
61mga is infamous around these parts
i suspect you're looking for something definitive... in that spirit all i can tell you for certain is that pirelli zero all-season 245/40r19 fronts and 285/35r19 rears (inflated to 32lbs PSI) do not make contact with wheel wells or fenders of my 2007 19" wheeled vantage. other than that i won't even speculate. however i will say that a socially awkward acquaintance of mine, out of the blue, said they looked like they were wider than the fenders and wondered if they rubbed.
Old Jun 13, 2021 | 01:44 AM
I have 285 on the rear now, and fitted with 23mm spacer kit I was looking for a tire that will protrude out by a few mm like I have on my Mustang GT I like the fat look
the 285 and the spacer bring the rubber to just in line with rear fender and by doing this make the car look lower if I go 295 I was hoping to get a more masculine look, the tire supplier is concerned the rubber could be to wide for the rim and then the side wall won’t seat correctly ad the problem that the tire needs to be ordered and not normally a stock item they don’t want to order and try they want to order and sell and I don’t want to order unless I know it will fit …
Old Jun 13, 2021 | 03:23 AM
61mga's Avatar
so success depends on if a 295 can be mounted safely on a standard vantage rear wheel, and if it won't rub on the rear fender, and if you can sweet talk the tire guy into ordering a 295 so you can "see if it works". ...that's a lot of "ifs".
there are any number of tire/wheel calculators on the net. so given the tire's width and height and the rim's diameter and width, it shouldn't be too difficult to answer the rim/tire compatibility and safety concerns.
Old Jun 13, 2021 | 09:15 AM
yes life in SA is not easy ….
Old Jun 15, 2021 | 02:46 PM
Gene G's Avatar
Gene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond repute
Looking on tirerack the 295 Michelin Pilot Sport 4S has a narrower tread width than the 285. Different tires might be the same size but differ in dimensions.
Old Jun 16, 2021 | 04:53 AM
handyman2009's Avatar
Veteran: Canadian Forces
usually the tire company will list the width of the rim needed for their tires, usually 285 is the widest that you should go on 9.5 inch rims which are the standard rim for a Vantage V8, check the Michelin site here
Old Jun 16, 2021 | 07:22 AM
MRCW's Avatar
rather than getting a wider tire, you may want to consider a wider stance with some spacers...
Old Jun 16, 2021 | 01:50 PM
AXARUNNER's Avatar
AXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to behold
I have a 2013 Vantage S and I'm running Michelin Super Sports 295/35 with no problems.
Old Jun 16, 2021 | 02:04 PM
Never said that it cant be done but not recommended for 9.5inch rims... 295 should be on 10inch rims minimum
Old Jun 18, 2021 | 07:30 AM
thank you 👍
thanks I will stay with 285 👍
secret agent
Nov 15, 2012 04:07 PM
Mr. C4
Jul 5, 2012 11:28 AM
YZWILLY
Mar 6, 2011 11:39 AM
ruffinit
Jun 28, 2008 08:45 PM
cerberusM5
Dec 18, 2003 12:43 PM
