Trunk issues 08 Bentley GTC
Old May 17, 2020 | 04:03 PM
AJ1's Avatar
AJ1
5 Year Member
AJ1 is infamous around these parts
Another positive outcome. It seems the common denominator is strut replacement.
Old Feb 20, 2021 | 04:30 PM
Daniel 08 Speed's Avatar
5 Year Member
Daniel 08 Speed is infamous around these parts
hood and trunk struts. Whos got'em, where can i get'em? Anyplace like local auto parts stores? what serial number should i look for or manufacturer number when shopping?
Thx dudes
D
Old Feb 20, 2021 | 06:10 PM
Doshhirao's Avatar
Doshhirao is infamous around these parts
I just got a set of hood struts (2 long,2 short) on eBay for 2007 flying spur. They were pretty easy to remove and install. Just needed a long screwdriver to get the clamps off
Old Feb 20, 2021 | 06:40 PM
Doshhirao's Avatar
eBay seller is alpineparts.
Old Feb 20, 2021 | 09:12 PM
5 Year Member
ill check them out thanx!
Old Apr 21, 2021 | 01:56 PM
fstick09's Avatar
Registered PM
fstick09 is infamous around these parts
Time to replace the motor
I have replaced my trunk struts, however the auto open still does not work. I can hear the motor humming, but it doesn't move the lid.
Does anyone have instructions for pulling the motor? I found the two bolts, but it still seems to be connected somewhere else (like the hinge).
Any help would be appreciated.
Gary
Old Apr 21, 2021 | 03:19 PM
Johnny Hotspur GT's Avatar
Administrator
Gary
Hello Gary @fstick09 ,
If you removed the two bolts as circled in my rebuild attached picture below, then you have removed the correct bolts, and there is no need to remove the bolts at the hinge, see the dowel guide nub cast onto the motor housing itself, you want to wiggle the motor out towards the quarter panel while moving the trunk lid up and down a bit to get the spline drive socket of the motor off of the spline shaft part of the hinge.
Johnny
Old Apr 22, 2021 | 09:57 AM
fstick09's Avatar
Registered PM
Thank you Johnny you are the man!
I removed the two bolts in my first attempt, but I don't think I wiggled it enough and didn't move the trunk. I will give it another go knowing it's not being held by anything else.
I suspect the motor has already been replaced prior to me getting the car as the two bolts are different. One is an 8 point like in your photos, but the other is a Torx.
Martin Perri
Bentley
29
Jul 4, 2024 06:01 PM
Martin Perri
Bentley
Mar 13, 2018 06:59 PM
evolveC4
May 4, 2013 09:46 AM
rynacd
Sep 8, 2012 09:39 AM
walks357
Jan 12, 2005 09:50 AM
