Changed both batteries now brake light is on and will not allow car to drive
Old Jun 27, 2019 | 07:13 PM
  #61
Xa Zen's Avatar
Xa Zen is infamous around these parts
I know it’s bad bad and dirty! As soon as I’m able to pull off I’m going to get a full tank and tires detailed before I get it wrapped/dipped!
Old Jun 27, 2019 | 07:16 PM
  #62
Samhain's Avatar
Samhain is infamous around these parts
Any reason a female couldn't date a woman who buys their partner a Bentley?
Glad to hear your car is feeling better.
Old Jun 27, 2019 | 07:18 PM
  #63
Xa Zen's Avatar
This is when I was saying the suspension was completely on the ground. But it lifted once I changed the buss bar and the 80 amp on the driver side battery.
Old Jun 27, 2019 | 07:31 PM
  #64
Xa Zen's Avatar
@Samhain 🤷🏽*♀️
Old Jun 27, 2019 | 07:32 PM
  #65
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
I tip my hat to you. Anyone who can get into the Bentley Quagmire and get out unscathed deserves three cheers.😉
Old Jun 27, 2019 | 10:07 PM
  #66
TeamJones1962's Avatar
Veteran: Navy
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
Nice 👍🏾..same color as mines. I hope you get it up and running soon. When you do, have the vacuum lines checked for leaks via a smoke test. The early years had an issue with them.
Old Jun 27, 2019 | 10:26 PM
  #67
Xa Zen's Avatar
You guys are too much 🤣. But you all helped me so much because I was a day away from just shipping it to the dealer to give away all my savings. I already saved a lot being able to order the fuses and change the battery and fuses myself. The mechanic claims he wants to video me doing my own oil change cause I refuse to pay hundreds to turn a few screws and let liquid drain out! Let me get past this tire properly first without killing the suspension! But I think I got it. I won’t do it without the mechanic present Infact he will prob do it i’ll Just be on his neck watching and directing 🤣. But he’s great himself but I need In on everything with this machine! So tomorrow is a new day guys ... let’s see if I get this done. Anyone know where I can get the front marker lights from. I have a connection where the guy is gonna charge 800 for both oem because they are 649 each at the dealer
  #68
Xa Zen's Avatar
@TeamJones1962 What are the vacuum lines for?
Old Jun 27, 2019 | 10:48 PM
  #69
Veteran: Navy
Don't quote me because I’m no mechanic but I think it’s dealing with the engine and can have your car running lean. I hear some leaks are bad and will give your car the feeling of a misfire. I have a leak but I have zero hesitation BUT I’m getting it fixed because I know it’s not supposed to be that way..lol. When I hit the gas, she moves!
Old Jun 28, 2019 | 08:02 AM
  #70
Xa Zen's Avatar
How much does that cost? Is that something the dealer has to do. I’m trying to avoid that place, but I will go if I have to
Old Jun 28, 2019 | 10:22 AM
  #71
joc44's Avatar
joc44 is infamous around these partsjoc44 is infamous around these parts
This is mine having vac line's done all in with parts £4,960.00 ouch
Old Jun 28, 2019 | 02:49 PM
  #72
Veteran: Navy
I gad mines done at the Audi dealership and paid around $150-$180 but I feel any mechanic worth his training could do it. Ask the guy you been dealing with, he may be able too or atleast point you to a shop that he’s comfortable with. I knew I had one because I did a Ross Tech scan and it basically came up with a vacuum leak code. I took it in as a second opinion.
Old Jun 28, 2019 | 02:51 PM
  #73
Veteran: Navy
That’s sounds about right. While mines apart I’m having my starter changed along with the turbo oil feed line, vacuum pump, spark plug and ignition coils . Not doing that twice!
Old Jun 28, 2019 | 03:35 PM
  #74
5 Year Member
Don't forget to do the O2 sensors/lambda sensors. The n75 and n249 sensors should get changed too. All of these are like us. When they get old they get lazy and eventually fail.😉
n75 boost control solenoid
n249 dump valve control solenoid
When those solenoids fail you can get overboost or no boost.
Old Jun 29, 2019 | 03:51 PM
  #75
Xa Zen's Avatar
@1eapplebaum Good evening guys. The car will not go into jack mode. Should the car be running when I put it in jack mode? Because I got in the car closed the doors started the car and put it in jack mode holding the two buttons on each side of the wing button. Should I do it with the car off?
