Need Help..Very Confused!!!
Old Sep 10, 2020 | 08:18 PM
1BD944T's Avatar
1BD944T is infamous around these parts
Guys
I have a 2011 Pan 4S with 50,000 miles... Here is the issue...Min oil level light came on..Checked oil level and its at the Min... I put 1 quart of Mobil 1 in and started car... Warning light still on and checked oil level still at Min.. From my understanding by opening and closing hood resets oil calibration... Never happened.. Warning light and oil level still at Min after adding quart and driving 2 days... Should I keep adding oil? Anyone else heard of this...I have read all the threads/Googled and youtube and havent found anything...Thoughts?
Old Sep 10, 2020 | 09:24 PM
turbo_mikePTT's Avatar
turbo_mikePTT is infamous around these parts
That’s a tough one, when was the last time you had an oil change? I would take it to the dealer have them do an oil change.
Old Sep 11, 2020 | 04:16 AM
shrike071's Avatar
shrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud of
Bad sensor would be my guess. I would not keep adding oil. If the oil level was really 2 quarts low, the light would have come on a lot sooner and you'd have to have ignored it for some time.
Old Sep 11, 2020 | 08:29 AM
allroadusa's Avatar
allroadusa has a spectacular aura aboutallroadusa has a spectacular aura about
Bad sensor for me as well.
Old Sep 13, 2020 | 08:42 PM
rgfinnegan3's Avatar
rgfinnegan3 is infamous around these parts
Mine sometimes takes 20 minutes of driving for the oil level to be revealed. I'm sure you are fine with one quart, that's what it needs when you are at min.
Old Sep 14, 2020 | 09:50 AM
Mozella's Avatar
Registered PM
Mozella is infamous around these parts
If my Panamera were doing this I would:
Drain the oil and measure the quantity. If it's several quarts below the specified quantity, your oil sensor might be OK. I''d refill with fresh oil and see if the sensor shows normal. Then you will have to find out why your car burns/leaks so much oil.
But chances are, it's the sensor and when you drain the oil you'll have the full quantity in your drain pan or (since you added oil recently) you might even have more than expected. That's not absolute proof of course, but as far as I'm concerned it is a VERY strong indication that your sensor is kaput.
I've never done it, but I did investigate the procedure and it looks like it's only slightly more complicated than doing a regular oil change, which you'll have to do anyway. Purchase the part, which isn't too expensive, drain the oil, remove the old sensor, put the new one in, connect it up, fill the pan with the recommend quantity of oil, cross your fingers, and it's a good bet that you're good to go.
At worst, you have a new sensor and you'll have to keep searching for the real problem, but it is a slim chance that the specific computer controlling your oil level display (one of the 3400 computers scattered around the Panamera) went semi-stupid. I'd bet on a mechanical malfunction of the sensor. A REALLY REALLY cheap guy might try to clean it up and reuse it, but at the expense of wasting an extra pan full of oil (or maybe more) it doesn't make sense. The part only costs a hundred and twenty bucks.\
Good luck. By the way, if you don't feel comfortable doing this yourself, I can give you the phone number of my mechanics. They have a certificate showing that they went to Porch school and the guy with no shirt has the nail pouch and hammer to prove it.
Old Sep 27, 2024 | 03:56 AM
negb's Avatar
negb is infamous around these parts
Question
Am I correct that in the photo bellow sensor is pluged in into flange no.21 ?
What for is this sensor ? I don't have any faults or incorrect readings, just a small oil leak, it is a bit difficult to determine from this layout diagram which one it is...
Originally Posted by ciaka
DIAGRAM of sensors locations - for your reference:
Thanks in advance.
Old Sep 29, 2024 | 04:52 AM
negb's Avatar
Found it :
https://www.6speedonline.com/forums/...id-change.html
this is solenoid valve for oil pump and it wasn't on that sensors layout diagram ....
in my case to stop oil leak through it and other weepings plus to change oil I will need Porsche OEM parts:
No.7 from this diagram: 2 o-rings for the solenoid 17x3 part no. 99970756740 - 2 x 2,36 eur
No.19 from previous diagram: 1 o-ring 44,0x3,0 for the flange part no. 99970757040 - 4,57 eur
No.14 from previous diagram: 1 gasket for oil sump, part no. 94810727521 - 37,60 eur
No.16 from previous diagram: 1 seal ring A18x24 for oil drain plug part no. 90012310630 - 1,47 eur
No.17 ( can be used instead of no.3 ) from previous diagram: 7 (just in case...) flat round head bolt M6x20 part no. 99907334401 - 7 x 0,91 eur
and from autoparts shop for 160 eur:
12 liter of 0W-40 Exxon Mobil 1
Mahle OX 254 D4 oil filter element WITH sealing ring
Mahle LAK 120 ACC cabin particulate filter
aarongobo
Cayenne 958
Jan 2, 2023 05:09 PM
lilo1980
Bentley
Nov 10, 2014 03:30 AM
jabed92694
Jun 6, 2011 11:11 PM
sand bandit
Cayenne 955/957
17
Dec 10, 2009 05:11 PM
davidTT
Sep 25, 2006 06:55 PM
