Relay switch help
Old Jun 8, 2022 | 10:48 AM
ZDPRx's Avatar
ZDPRx is infamous around these parts
Question Relay switch help
I have 2012 Panamera that I managed to hit a football size rock on the highway. It ripped of my serpentine belt and the AC compressor pulley. I have replaced the AC compressor and belt...charged the AC with coolant. The problem now is that I must directly power on the compressor to a 12v source to engage the clutch.
I am thinking it may be the relay switch but cannot, for the life of me, find it. I've searched all over the car as well as the internet yet still I can not find. Can anyone point it out to me.
Cheers
Old Jun 9, 2022 | 06:50 AM
HP41's Avatar
HP41 is a jewel in the roughHP41 is a jewel in the roughHP41 is a jewel in the rough
See if this helps ....
Old Jun 9, 2022 | 07:39 AM
ZDPRx's Avatar
I appreciate this help so much . I'm at work but will play around with that this evening.
Thanks again!!
Old Jun 10, 2022 | 08:13 AM
ZDPRx's Avatar
Relay?
This is the pressure sensor I belive...not the Relay.
Old Jun 11, 2022 | 05:02 AM
HP41's Avatar
You are correct. --- not what you were looking for.
This is a wiring diagram of the A/C system. It might help in diagnosis.
I'll look for a relay location diagram.
File Type: pdf
Old Jun 15, 2022 | 10:27 PM
ZDPRx's Avatar
Still can not find the relay.
I'm about to go crazy...behind passenger seat...in yrunk...in engine compartment infront of driver!!!
I've heard it all.
Does no one know?
Old Jul 17, 2022 | 07:27 AM
ZDPRx's Avatar
Anyone
Still can not find AC relay switch...any help would be appreciated.
Old Jul 17, 2022 | 01:24 PM
Deezflip's Avatar
5 Year Member
Deezflip is infamous around these parts
Have you inspected that pressure switch to make sure it's not faulty or damaged? It may be the thing that engages the clutch, just thinking out loud. Not definite
https://www.sunsetporscheparts.com/o...or-95561313703
Old Jul 22, 2022 | 09:41 AM
ZDPRx's Avatar
I did last night...I think you may be correct. Multimeter showed no life
Old Jul 22, 2022 | 09:54 AM
Deezflip's Avatar
5 Year Member
Great, I hope it's just that.
From the looks of the wiring diagram and that fact that no one knows where it is, there might not even be a relay switch for it. I did find a relay, but I think it might just be for the internal fan/blower
Old Jul 22, 2022 | 10:31 AM
ZDPRx's Avatar
I do belive you are correct on both counts. The meter had no continuity and that would mean that the circuit would not be complete...thus, no power to the compressor. Thank you for your input. I have a new sensor on order and that should do the trick!!
It's only 112 degrees here in Texas...whats another week or so without AC!!
spqa
May 27, 2022 11:26 AM
cinellipro
Aug 30, 2015 03:48 PM
pdogfly
Apr 16, 2014 08:56 PM
Sharkbit
Aug 22, 2013 08:32 AM
Turbohead
Jul 5, 2011 07:30 PM
