Water pump
Old Apr 14, 2023 | 01:15 PM
melox2's Avatar
melox2 is infamous around these parts
Water pump
As anyone done a water pump charge on a 971 model if so is it straight forward and doesn’t affect the timing belt
Old Apr 15, 2023 | 10:33 AM
Marc13190's Avatar
Marc13190 is infamous around these parts
No there is on link with distribution. It's a V8 ?
Old Apr 15, 2023 | 10:37 AM
melox2's Avatar
Yes V8 turbo
Old Apr 17, 2023 | 03:36 AM
Marc13190's Avatar
You can change water pump without problem. How many kilometers you have ? I think if you change pump you can change thermostat.
Old Apr 17, 2023 | 06:50 AM
melox2's Avatar
It’s done 36000 miles. Got a leak above pulley but not 100% it’s pump or the o ring or there’s a small pipe that pushes in engine to thermostat housing
Old Apr 23, 2023 | 02:02 AM
melox2's Avatar
Just to update water pump seal had gone with only 35k mileage, Easy diy swap tho
Old May 14, 2023 | 09:02 AM
Marc13190's Avatar
You have change only seal ? or pump ?
Have you change thermostast ?
Old May 14, 2023 | 10:14 AM
melox2's Avatar
Replaced the water pump complete, very easy diy job and only need to remove a few bits above to get access , I also replaced the thermostat
Edward Fitz
Cayenne
Jan 19, 2022 08:04 AM
Argus
Sep 19, 2018 10:59 AM
Hatzenbach
May 10, 2013 05:22 PM
porsche02
911
Nov 27, 2012 09:10 AM
vshugo996
Nov 14, 2012 11:39 AM
