997TT MK.1 PCM 3 conversion DONE :)
I have the 997.1.5 HVAC, from the 2009 Turbo detailed in this post. All I have to do is move 1 wire from the red block to the black block. For what you want to do using a 997.2 HVAC it seems a lot more complicated, and from what what I've read I'm not sure there is a complete solution.
I got the plug from ebay, but like Serg said, you can get it from a VW/Audi dealer too.
Could you confirm?
It's not just moving the one wire, it also requires PIWIS programming. If you read the thread of the link in my last post you will see that. Not sure when I will be able to get to the dealer to have that part done.
My question was a bit ambiguous - I was specifically curious about the electrical re-wiring.
...and it sounds like there's nothing further needed from an electrical and hardware perspective.
Hi all,
Big thanks for this incredible thread.
I have another stupide question, I need to test the wire of my rear camera but I don't know where I can find it at the back of the PCM 3.0 ...
Maybe one of those Fakra connectors ?
Can you please tell me the function of each red/black/blue ?
Thanks for your hellllllp !!
In the 1,5gen turbo it works, so i think there should be a possibility to get it working?
Maybe you explain what you wrote here, because this is look like I'm not honest with you or someone else. And that's not the true.
And to make everything clear - I don't do any looms or harnesses, never did and never want in fact. This is wrong way, don't ask me for this, and this will make administration happy.
Thank you.
Thank you.
