WOW! ROTtec 997.1 DRL LED's
Old Dec 21, 2011 | 03:50 PM
  #181
TT2911's Avatar
TT2911 is just really niceTT2911 is just really niceTT2911 is just really niceTT2911 is just really niceTT2911 is just really nice
Originally Posted by DirtyVegas
What I do not get is that if it is a light module in our cars that is the issue, why is it that only one side is affected and not both? Shouldn't we be then seeing lights out on all sides? And what about other issues? There are just too many of them. I really think that this is a LED DRL quality and assembly issue rather than our cars.
I think the design/quality is bad for this product all together despite it 'looking good' to an outside observer, and that it has predominantly affected the right side light assembly for which we now have to use an outside resistor for.
I appreciate the potential resolution to this, but I just do not appreciate my car being blamed for a problem that seems obviously related to the product design/quality. I mean how many of us have bought the Depo/Dectane lights, and how many had issues? Very few. If the math is done, it is obvious that these LED DRL have a much higher defect rate than other similar products that we use. I think this product was rushed to market under poor design/quality despite the delays and the resons given us stating the opposite.
This type of problem is not unique to these LED front lights. Any time you replace OEM lights with any type of LED's you run the risk of triggering the "light failure" circuit in any car equipped with a monitoring system.
The system is designed to work with regular incandescent bulbs that use a filament that draws a very predictable amount of current. If the current draw goes down or away the system interprets that as a failed bulb. LED's by their nature have an extremely low current draw. In some cars you won't get an alert due to minor variances in the sensitivity of the monitoring system. Or your car may have different factory options than another car. This can result in your car having a different wiring loom that the other car. A longer or shorter wiring loom can change the resistance in a given circuit enough to impact whether the monitoring system alarms or not.
Vendors can take the belt & suspenders approach and ship resistors with every kit but that adds extra cost and many people wonder what the resistors are for when the install their lights and they work fine (like mine) without the resistors.
I also remember lots of folks having similar issues with the Dectane rear LED's when they first came out. Some needed resistors, many didn't.
Old Dec 21, 2011 | 03:55 PM
  #182
Jack667's Avatar
Jack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant future
Originally Posted by drive2006c4s
thanks for the quick reply Jack667!
but I don't have that tool kit that came with the car.
I'm sure there is different tools that fit in the bolt. anyone?
thanks...
You'd probably need a 1/4 inch socket set with a long, thin extension. The bolt is probably 4mm or nearby to that. It doesn't have to be a deep socket, but the extension should probably be 12".
Maybe someone can post something more specific.
Maybe something like
this this
, and
this this
would do the trick, or similar items from your local Sears, Home Depot, etc
Old Dec 21, 2011 | 06:23 PM
  #183
lopro's Avatar
lopro is a splendid one to beholdlopro is a splendid one to beholdlopro is a splendid one to beholdlopro is a splendid one to beholdlopro is a splendid one to beholdlopro is a splendid one to beholdlopro is a splendid one to behold
a 1/4" extension, every person on the planet should have one. you know what they say about a man without tools
Old Dec 21, 2011 | 09:03 PM
  #184
///MJFDDS's Avatar
///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute
Happy to report that I have installed my DRL's and have no codes! They look fantastic... thanks Ray!
However, I also installed the replacement Xenon's and have an issue with one of the bulbs wanting to go out after being on for a few moments. I assume it's a resistance problem (bulb heating up). Will be contacting Ray about it. Anybody else run into this issue?
Old Dec 21, 2011 | 11:56 PM
  #185
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
One of your HID bulb was defected unit and I can arrange replacement to you. PM sent!
Old Dec 22, 2011 | 12:24 AM
  #186
Ray's Avatar
Ray
Resistors arrived and I will mail them out tomorrow!
Old Dec 22, 2011 | 12:42 AM
  #187
v35's Avatar
v35
v35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond repute
This is great news for everyone! This after-purchase support is what sets you apart from the overseas distributors, keep it up Ray!
Old Dec 22, 2011 | 07:34 AM
  #188
louie007's Avatar
louie007 is infamous around these parts
I second that , great after sales support , thanks Ray
Old Dec 22, 2011 | 07:50 AM
  #189
cavsct94's Avatar
cavsct94 is a splendid one to beholdcavsct94 is a splendid one to beholdcavsct94 is a splendid one to beholdcavsct94 is a splendid one to beholdcavsct94 is a splendid one to beholdcavsct94 is a splendid one to behold
Huzzah!
Old Dec 22, 2011 | 09:55 AM
  #190
///MJFDDS's Avatar
Thanks for the quick response Ray! Happy Holidays...
Old Dec 22, 2011 | 06:20 PM
  #191
fgg's Avatar
fgg
fgg is infamous around these parts
Hello Ray, just came back from a trip and I install the DRL's lights with no code errors! they look amazing . Next will be the HID bulbs that I got from you....
Best Regards
Freddy
Old Dec 23, 2011 | 01:45 PM
  #192
Ray's Avatar
Ray
Thanks everyone! All resistors has been mail out by air yesterday and they should arrive within a week! Happy Holiday!!
Old Dec 23, 2011 | 02:05 PM
  #193
lopro's Avatar
top man ray. your customer service is +1
Old Dec 23, 2011 | 04:35 PM
  #194
cavsct94's Avatar
Yep.
Old Dec 23, 2011 | 05:20 PM
  #195
NJM500's Avatar
NJM500 is infamous around these parts
My resistors work perfectly and I fitted the Xenon replacement HID bulbs today that I got from Ray. Look really good.
Ray - is there an o
