Tuning/Modifications
KA - In Memory of my Mom (Vincee) and best friend Michael J. Maring
Old Aug 28, 2003 | 07:29 AM
  #61
cjv's Avatar
cjv
Moderator
John,
Hamann's Protomotive built car is now going to be included in the test.
Old Aug 28, 2003 | 06:09 PM
  #62
HotRodGuy's Avatar
awesome, this is going to be one hell of a test.
btw, hope the larger injectors work out
Old Aug 28, 2003 | 06:49 PM
  #63
PorschePhd's Avatar
We run 72 on batch systems and can idle like a kitten. We run 82 and higher on sequential fire systems. The quality of the injector will dictate how well it can be tuned. Not all injectors are created equal. You should have no issue running higher than 73. Also in theory 73 will not be enough to support 805HP...
Old Aug 28, 2003 | 07:18 PM
  #64
sharkster's Avatar
hey cjv, kinda personal question here (well concerning turbos lol) but I was wondering how much air flow you see from your guys? I've logged 47 pounds per minute although my car's not yet running correctly nor is it tuned right yet... I was thinking you should be around 70? Kevin's turbos apparently flow up to 62 pounds per minute...
Old Aug 28, 2003 | 07:28 PM
  #65
cjv's Avatar
cjv
Moderator
Stephen,
You are correct. Seventy three pound injectors will not support 682 rwhp. However, you must look at what it is really supporting. In reality it is supporting 516 rwhp in mode one at 1.1 bar. It is assisting 614 rwhp in mode two at 1.25 bar. It supporting 635 rwhp in mode two with CO2 assist. The 682 is accomplished with fifty shot of N20. The N2O is a wet system and the plume injectors provide both N20 and fuel. By the way we still have one jet size to go. On paper we have the potential of 702 rwhp with the next step.
So Stephen, with the above information.... what poundage number would you run?
Old Aug 28, 2003 | 08:04 PM
  #66
cjv's Avatar
cjv
Moderator
sharkster,
I don't know.
Old Aug 28, 2003 | 08:23 PM
  #67
PorschePhd's Avatar
Well if you actually run 702 the 82# would fall a little short if you were looking at the max duty cycle. There are so many variables to injector size that it is not cut and dry. Things such as rail pressure and once again the quality of the injectors. Some injectors handle going up higher than others. I know nothing of RC in regards to quality. I would start with the 82#.
Old Aug 28, 2003 | 09:05 PM
  #68
cjv's Avatar
cjv
Moderator
Stephen,
I am not sure if I am explaining myself clearly. The injectors for the NOS N2O are a complete second set. These injectors are in addition to the RC Engineering Injectors. The NOS injectors inject both N20 and the additional fuel for the N2O.
Old Aug 28, 2003 | 09:13 PM
  #69
PorschePhd's Avatar
Well, that would work. The only issue is 7.8 doesn't have any way to control a GPO. I supect you still will be using an AIC of some nature?
Old Aug 28, 2003 | 09:26 PM
  #70
cjv's Avatar
cjv
Moderator
The NOS (Nitrous Oxide Systems) injectors are controlled by the NOS Digital Programer. The fuel system must have 51 psi of fuel or the NOS system will shut down, the clutch sensor must sense the clutch is not depressed, you must have wide open throttle, you must be in the rpm range of (in my case and it is adjustable) 4400 thru 6600 rpm's (DIS Window Switch). Once the system is activated the programmer pulses the N2O and fuel in 10 rwph shots, increasing by ten hp every 1/10 of a second, ie. 10, 20, 30, 40, 50. So at the end of one half of a second, fifty rwhp has been added.
Old Aug 29, 2003 | 07:53 AM
  #71
PorschePhd's Avatar
Ahhh ok, so they have an AIC already aligned with the progressive control. Nice idea. NOS hardware has come a long way since I played with it aggressively. LOL, it will have to go a lot longer though before I play with it again. Better you than me
Old Aug 29, 2003 | 05:33 PM
  #72
cjv's Avatar
cjv
Moderator
Stephen,
Soon I will be taking it one step further. Putting temperature probes on each header tube where the exhaust exits the exhaust port.
Old Aug 29, 2003 | 06:09 PM
  #73
PorschePhd's Avatar
Next should be a set of these.....
Old Aug 29, 2003 | 06:10 PM
  #74
PorschePhd's Avatar
Then 4 more of these....
Old Aug 29, 2003 | 07:37 PM
  #75
cjv's Avatar
cjv
Moderator
Stephen,
Already have my rods. What are you trying to say in the second pic?
You have already rated this thread Rating: Thread Rating: 90 votes, 4.16 average.
